| Some parts for sale! http://woodsbuggy.com/phpBB3/viewtopic.php?f=7&t=12624 |
| Author: | jackson.ryan29 [ Thu Nov 17, 2011 8:06 pm ] |
| Post subject: | Some parts for sale! |
Muale (87) with brand new rings only maybe an hour on them! $200 Engle 110 also an hour on that! $60 Progressive (weber) with off road air cleaner set up! $200 Set of daul port heads .110 flycut $80 |
| Author: | jackson.ryan29 [ Thu Nov 17, 2011 8:08 pm ] |
| Post subject: | Re: Some parts for sale! |
Plus 87 have Teflon buttons |
| Author: | jackson.ryan29 [ Thu Nov 17, 2011 9:23 pm ] |
Also 1.25 rockers with the lash caps only and hour on them $120 Reason for saleing all this is cuz I'm building a 1915 and can't use any of this stuff figured someone was building a motor and could use some good parts! |
| Author: | ridenrace6 [ Fri Nov 18, 2011 3:59 am ] |
dont mean to hijack but i would put the 110 cam and 1.25 rockers on the 1915 if it were mine and nothings wrong with them then throw on a good set of o44 heads and dual idf webers and you should have a real good running engine jmo. |
| Author: | JeffClay [ Fri Nov 18, 2011 8:58 am ] |
ridenrace6 wrote: dont mean to hijack but i would put the 110 cam and 1.25 rockers on the 1915 if it were mine and nothings wrong with them then throw on a good set of o44 heads and dual idf webers and you should have a real good running engine jmo. x2 |
| Author: | jackson.ryan29 [ Fri Nov 18, 2011 4:54 pm ] |
Going with a vz15 like the way it sounds and proformace is also sweet! |
| Author: | ridenrace6 [ Sat Nov 19, 2011 12:35 am ] |
jackson.ryan29 wrote: Going with a vz15 like the way it sounds and proformace is also sweet! yeah thats what i have in my 1915 but after climbing with it i wish i had a 110 and 1.25's, the vz15 runs likes crazy from 2000 rpms and up but doesnt like to lug around down low, at least mine dont |
| Author: | jesse [ Sat Nov 19, 2011 1:04 am ] |
110 is the way to go in this situation |
| Author: | AB250r [ Sat Nov 19, 2011 1:31 am ] |
Go scat c45 love mine! |
| Author: | jackson.ryan29 [ Sat Nov 19, 2011 9:46 am ] |
Was going to go with the crower 4? Also but not sure never seen a crower run! |
| Author: | Roy [ Sat Nov 19, 2011 11:12 am ] |
Crower split duration runs the best in an air cooled VW motor. Especially with dual carbs. |
