It is currently Mon May 04, 2026 12:04 pm
 Post subject: WTB tranny
PostPosted: Thu Apr 21, 2011 5:36 pm
Wanting a 3, 5, or 6 rib preferably kinda close to southern IN
Great if in working order :D
 Post subject: Re: WTB tranny
PostPosted: Thu Apr 21, 2011 6:14 pm
not mine but looks like a good deal
http://louisville.craigslist.org/pts/2331375122.html
PostPosted: Thu Apr 21, 2011 8:05 pm
i have a good side shift in nose cone 6 rib. works 100%. i am from eastern ohio but can have taken to kentucky just across bridge from cincy. 400 bucks. or i can deliver to wellsville if that helps
PostPosted: Thu Apr 21, 2011 8:34 pm
If your ever in London Ky. I have a 3 rib $325. 606-306-2464 call if interested
PostPosted: Thu Apr 21, 2011 8:59 pm
091 diesel side shift whats the R&P on one?
are all 091's side shift?
PostPosted: Thu Apr 21, 2011 11:09 pm
i have a 5 rib in great working order it has never been in a buggy, i will take $500.00 for it i live in london ky,
PostPosted: Thu Apr 21, 2011 11:29 pm
R&P?
PostPosted: Fri Apr 22, 2011 2:26 am
if your asking about the 1 in the CL add its not a 091 its a 002(3rib) side shift,,,the 3 I have are 586r&p
PostPosted: Fri Apr 22, 2011 6:38 am
So you've converted to nose cone shift on the one you would sell?
new to the buggy world so talk to me like im stupid :mrgreen:
Any pics
PostPosted: Fri Apr 22, 2011 8:25 am
Got a buddy with several 3-ribs to sell.
PostPosted: Fri Apr 22, 2011 4:36 pm
where are you located? i have a 6 rib and 3 rib side shift... im in owensboro ky
Don't let out when in doubt!!
PostPosted: Mon Apr 25, 2011 10:24 am
my side shift in nose cone is a 4.86. this one can be converted to nose shift if you would want to have it done. not really sure on what that would cost
PostPosted: Mon Apr 25, 2011 9:02 pm
Doesnt Davis racing make linkage for one
Can you post pics of you trans mudnut
PostPosted: Tue Apr 26, 2011 11:40 am
told ya too call me....
PostPosted: Tue Apr 26, 2011 3:44 pm
Unless its a midshift (watercooled) trans, I wouldnt bother tryin to run a sideshift.
PostPosted: Tue Apr 26, 2011 3:54 pm
Whys that?
isnt the reverse gear just stronger on the midshift?
Gonna be using a stock for now 2.2 suby for power
suggestions would be appreciated.
PostPosted: Wed Apr 27, 2011 10:56 am
I run a 6 rib nose shift in mine, I've broken everything in that stock tranny including the case.
I cured that by adding a 4 spider diff and $1500 of weedle gears and bearings,thrust plate etc...even then I jerked the pinion bearing into.
The only reason I would start with a nose shift 6 rib over the waterboxer side shift would be that weedle offers more after market gear ratios 1-4 than it does for the side shift.
Everthing in the waterboxer side shift in stock form is stronger.
