It is currently Mon May 04, 2026 5:23 pm
 Post subject: 1776 engine
PostPosted: Sat Nov 20, 2010 7:51 am
http://www.woodsbuggy.com/index.php?opt ... =7&t=10471 . I have up for sale an engine kit to make a 1776. The case has been machined and is a TYPE 3 case that comes with the dipstick tube piece. The heads are clean and ready to run at 39mm int, X 32mm ext. The crank is turned, the rods are rebuilt( Chirco) the pistons and cylinders (90.5) are used but come with new rings. The cam and lifters are used (lightly) , all the bearings are NEW. Also included are the oil pump, fuel pump, gaskets, flywheel, clutch disk, pressure plate, oil coolers, 2 fan shrouds, dist., wires, push rods, generator stand. You will need a generator, dual port head tins, and a dog house fan shroud if you want to run the larger oil cooler. The dog house oil cooler is included. The asking price is...........800.00 OBO and I mean OBO :lol: I could also use a set of 2X3 arms, 3" body lift Dell or Weber carbs as part of a trade. Thanks Dave T Zeeland MI 49464 Image , Image , Image , Image, Image , Image , Image , Image.
