It is currently Mon May 04, 2026 9:00 am
 Post subject: 1776 engine parts
PostPosted: Wed Nov 17, 2010 7:38 pm
ive got everything to make a 1776 engine. 90.5mm mahle piston and cylinders heads cam crank will sell all or split up
Brandon
 Post subject: Re: 1776 engine parts
PostPosted: Thu Nov 18, 2010 5:42 pm
90.5mm make 1776 & 92mm make 1835 on a 69mm crank . what heads & cam & block do you have.
PostPosted: Thu Nov 18, 2010 6:07 pm
not sure about the cam vw heads and vw block
Brandon
PostPosted: Fri Nov 19, 2010 7:46 pm
How much?
PostPosted: Fri Nov 19, 2010 7:52 pm
depends on which parts you want/need
Brandon
