 Post subject: 6 rib side shift SOLD!!
PostPosted: Fri Oct 22, 2010 9:08 pm
Came out of a 84 vanagon, 4 spd go's into all gears. $450
Awesome 2387 Beeline Cobra
 Post subject: Re: 6 rib side shift
PostPosted: Fri Oct 22, 2010 10:44 pm
what is the vin code on the side of the trans
PostPosted: Fri Oct 22, 2010 11:49 pm
I could not read the vin code on the side but i got the gear code and it starts with DU. hope this helps
http://www.partsemporium.co.uk/t25gearboxcodes.htm
PostPosted: Thu Dec 16, 2010 2:47 pm
still for sale
PostPosted: Sat Dec 18, 2010 2:35 pm
Where do you find the gear code on the trans? I wrote down the serial # and it ended with d2.Cant find it on chart
PostPosted: Sat Dec 18, 2010 5:34 pm
if you flip trans up on bell and look at the bottom of it it will be on the left side on the bottom a space about 1" x 4" flat.
PostPosted: Sun Dec 19, 2010 3:18 am
Pull up http://www.partsemporium.co.uk then type 25 gearbox codes(british for transmission) type 25 means vanagon.It gives ALL bus trans ratios.
PostPosted: Tue Dec 28, 2010 2:39 am
open to trades. what do you have
PostPosted: Tue Feb 08, 2011 11:52 am
sold!
