wtb irs rearend
http://woodsbuggy.com/phpBB3/viewtopic.php?f=7&t=10085
Author:  hcoabel [ Mon Aug 16, 2010 2:12 am ]
Post subject:  wtb irs rearend
Looking for a bus etc... rear i can use to convert to irs so i can install a 3 rib i have swing axel n swing axel tranny now
Author:  Russ-the-Buss [ Mon Aug 16, 2010 6:38 pm ]
Post subject:  Re: wtb irs rearend
I have 2 rear IRS torsions that came from Bugs..all you have to do is drive over here and choose which one your taking home with you !..If they will work?
Author:  hcoabel [ Tue Aug 17, 2010 9:47 am ]
Where are u located?
Author:  Stevo [ Tue Aug 17, 2010 5:19 pm ]
I have one I would sell. Let me know
Author:  Russ-the-Buss [ Tue Aug 17, 2010 6:09 pm ]
If You look under my avitar i think it says Atlanta Inidana,,,lol,,Its about 30 miles north of Indianapolis IN. And just so you know..either is free. just glad to help out.
Author:  hcoabel [ Tue Aug 17, 2010 10:27 pm ]
Well moter went out in the expedition today so gotta go buy another one this week once i get it maby well come out
Author:  1641buggy [ Tue Aug 24, 2010 10:50 pm ]
i think i my have a stock set of irs trailing arms.you can buy the trailing arm pilet mount and bolt.all you have to do is weld them on put the bolt in and hang the trailing arms.i also have a brand new set of bushing to go with them.or would it be easier to weld in a whole irs clip..???
Author:  hcoabel [ Thu Aug 26, 2010 10:01 am ]
I think welding in the pivots would wprk just fine, then bolt a set of trailing arms on and cut down the spring plate to mount to the trailing arm, so I guess I need to find a set of trailing arms perferably best ones for a 3 rib and hopefully used
Author:  Russ-the-Buss [ Fri Aug 27, 2010 12:15 pm ]
You could still come and get one of these torsions,,remove the stock arms, weld in beef up kits, put them on your buggy,,,Bam,,,their used,,and FREE !
Author:  hcoabel [ Fri Aug 27, 2010 1:13 pm ]
Yes my only problem is I live in canton ohio n have three kids lol so finding time for it is hard unless u r going to wellsville labor day weekend
