It is currently Sun May 03, 2026 11:58 am
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Jan 10, 2014 12:14 pm
The arms do not come with bearings or seals. I can provide them at an additional cost.
As far as what material I used, right after you buy a set, I'll let you drill a hole into them to find out.
Now, how thick do YOU think they are to survive this, not once, not twice........
https://www.youtube.com/watch?v=gYIXHrH ... ata_player
PostPosted: Sat Jan 18, 2014 4:22 pm
[quote="MadMike"]I build everything suspension including front arms and spindles, wheel adapters, beams, torsion eliminators and rear trailing arms. If you need something that is not listed, all it takes is a phone call. 724-650-0816
Wheel adapters. VW 4 bolt to race wide 5 $150
Hey MadMike, do you think a set or 1 of these would work as an adapter for BALANCING tires for the wide 5 rims?. None of the tire shops can do this because of the hole in the middle. Thanks Dave T
PostPosted: Sun Jan 19, 2014 7:13 am
I wouldn't trust them for doing balancing. They are just a piece of flat plate. Something like that would need to be specifically made for that use.
PostPosted: Sun Jan 19, 2014 9:46 am
Thanks.
PostPosted: Sun Jan 19, 2014 9:04 pm
Hey mike can you get a price on a chromoly beam stock width without shock towers, with good king kong adjusters?
WTFO
Loud pipes save lives.
PostPosted: Mon Jan 20, 2014 4:31 pm
Sorry Hunter, I don't make chromolly beams, they bend too easy and they aren't worth the time to build. I'm also staying away from torsion spring beams, too much involved to make them cheap enough to buy for the average joe.
PostPosted: Thu Jan 23, 2014 12:44 am
Just guesstimating, even if you went with your heavy wall with a good set of adjusters or say i supplied my own. Would you be interested at all? Or is it a flat no?
WTFO
PostPosted: Thu Jan 23, 2014 9:21 am
Where u located mike. I will be interested in some drop spindles in the near future
PostPosted: Thu Jan 23, 2014 8:55 pm
There is nothing in the aftermarket that supports what I build, everything is custom made. I would need to make the adjusters in addition to the beam, which takes time which equals $$. I'll build you anything you can afford, and then some.
I also would need to come up with a stock beam, which I haven't had in around here in years, to get a starting point for the adjuster angle.
I'm NOT saying no, I'm just saying NOT cheap.
I'm located in the tundra, right next to Nanook's place, you know, somewhere between lost and found.
Pittsburgh, "north pole", PA
PostPosted: Thu Jan 23, 2014 9:24 pm
OK mike I'm from st.clairsville Ohio area. So ur not far
PostPosted: Thu Feb 06, 2014 1:10 pm
Mike you done a great job on my torsion eliminators I really appreciate it they look great .
PostPosted: Thu Feb 06, 2014 1:22 pm
I think your car makes them look good, thanks Darrell.
PostPosted: Sat May 31, 2014 1:54 pm
Got a fresh batch of torsion eliminators made.
PostPosted: Sun Jun 01, 2014 10:43 am
When we quit playing phone tag lol. I will take a set.
Bo
PostPosted: Sun Jun 01, 2014 11:00 am
Bo
Timing is everything. :) By the way, your it.
PostPosted: Tue Jun 03, 2014 8:07 pm
I have one set of torsion eliminators left, so if you need them, or if you even think you need them now is the time. This will be it for a while, between customer work,the Funco project and the building I'm in the process of buying and everything that goes with that, I"m getting stretched real thin.
PostPosted: Thu Jun 05, 2014 1:07 pm
These things look great. Thanks Mike!Image
PostPosted: Thu Oct 09, 2014 3:00 pm
Bump
PostPosted: Mon Nov 03, 2014 9:21 pm
Anyone do any shooting? I've been making pistol only shooting trees. This is a reactive target set up, hit it on one side it pivots around to the other side. The base of this also has the ADPA target pockets $275 + Shipping
PostPosted: Mon Nov 03, 2014 10:53 pm
are the targets made of hardened steel
PostPosted: Tue Nov 04, 2014 12:08 am
No, that's why I said Pistol Only
PostPosted: Tue Nov 04, 2014 10:36 am
Ok.
PostPosted: Thu Nov 20, 2014 6:08 pm
I'm going to have a set of 3X3 rear trailing arms available late next week if anyone is interested.
PostPosted: Thu Nov 27, 2014 3:12 pm
Hey Mike, much your 3x3's with bearings installed cost?
PostPosted: Thu Nov 27, 2014 8:44 pm
I would have to see what bearings cost, but putting bearings in is kinda easy. 500 watt quartz light to warm up the housing for about a half hour, you can put bearings in from the other side of the room.
Personally, I would wait till after you weld the shock mounts, caliper brackets and painted and stuff before I put bearings in.
I should have those 3X3's ready to ship first part of next week. :wink:
And if anyone has type 1 bearing spacers, the tube one in between the bearings, I need them.
