It is currently Mon May 04, 2026 9:30 am
 Post subject: 2110cc VW Engine
PostPosted: Wed Mar 17, 2010 6:10 pm
VW longblock engine.
94mm bore x 76mm stroke.
Welded c/w crankshaft.
Mahle piston kit.
Autocraft modified VW case.
10mm heads studs with case savers.
40x35.5 valve ported/polished heads.
Port matched IDF intakes included.
C channel valve covers.
CB performance oil pump.
Engle FK42 camshaft.
1.25 Rocker arms.
10:1 compression ratio.
CM pushrods.
New distributor.
Newer fuel pump.
Stock weight flywheel w/1-1/2" CM gland nut.
Sand seal pulley.
Freshened beginning of last year.
$1250
This belongs to a customer that is building a new 2332.
 Post subject: Re: 2110cc VW Engine
PostPosted: Thu Mar 25, 2010 11:51 am
http://www.e30tech.com/forum/showthread.php?t=87516
i will trade you for the motor
PostPosted: Thu Mar 25, 2010 1:12 pm
Not mine to trade.
Listing it for a customer.
PostPosted: Fri Mar 26, 2010 11:39 am
Pending
PostPosted: Fri Mar 26, 2010 5:39 pm
Sold
Thank you Mr. Anderson.
Will deliver to Drew's Sunday.
PostPosted: Wed Apr 14, 2010 8:33 am
Hey I'll trade you my subaru and conversion kit for it. The motor will crank and run, but it's leaking exhaust into the coolant system somewhere. Replaced the head gaskets, and it's still doing it Who knows maybee I just didn't tighten them down good.
PostPosted: Wed Apr 14, 2010 10:32 am
not sure... but im thinking it is sold...seeing that the last post said "sold"
