It is currently Mon May 04, 2026 9:03 am
 Post subject: WTB 1600ish and 3 rib
PostPosted: Sun Aug 16, 2009 6:53 pm
Had a engine and tranny lined up but I think he backed out. Looking for engine and tranny for my daughters buggy.
PostPosted: Mon Aug 17, 2009 7:43 pm
I've got a 3-rib, $250 picked up in Holland, MI, or I could deliver to the Bug Run on the 30th if you'll be there.
Check out www.Thegoodvolks.com!
PostPosted: Mon Aug 17, 2009 9:02 pm
How about warsaw, in area?
PostPosted: Thu Aug 20, 2009 12:06 pm
how about a bad a## 1915 and a 5rib turn key everything bolt on and go motor has 2 rides to get tuned in and a fresh tranny
PostPosted: Thu Aug 20, 2009 1:35 pm
not tryin to steal the post nitro mudder but how much for the 1915 and trans?
Brandon
PostPosted: Thu Aug 20, 2009 2:16 pm
3500.00 i have over 4500.00 in everything like i said it is all new
alum case,scat crank,scat rods,crower 04 cam,scat lubeo lifters,mayle pistons,bug pack street elim heads,1.25 rockers,cromoly pushrods,new alt,44 weber,009 with pertronics,pertronics coil,12lb flywheel, stag2 pressure plate,
1 1/2 u bend header, the trans has 091 big 1st gear all hand pack bearings, new syncros, cromoly pinion nut, bearing plate.steel shift ball, i probly forgot some thing but you get the picture.
PostPosted: Thu Aug 20, 2009 10:14 pm
Have at it Brandon, out of my price range for my 14 yr old, lol. Found a fresh rebuilt 1600 for $350. Gotta go check it out. Still need the 3 rib yet. Who was in MI with one?
PostPosted: Thu Aug 20, 2009 11:28 pm
out of my price range too :shock:
Brandon
PostPosted: Fri Aug 21, 2009 8:54 am
I've got the 3 rib in MI. Also have a used FI 1600 long block, AS21 Case, no fuel pump mount. But, it sounds like you already have a complete engine lined up.
