It is currently Mon May 04, 2026 11:10 pm
 Post subject: i need a winch remote
PostPosted: Sun Jul 05, 2009 2:34 am
im lookin for a winch remote 4 my buggy my old one messed up anyone have a extra 2 way winch remote they wanna selll? if so give me a holler
Brandon
PostPosted: Sun Jul 05, 2009 4:49 pm
my suggestion is 2 mount a three way toggle switch in ur buggy and hook it up that way it works out pretty good
PostPosted: Sun Jul 05, 2009 10:47 pm
sounds like a plan but i suck at wiring some stuff and i believe that would be one of them haha
Brandon
PostPosted: Thu Jul 09, 2009 9:41 am
Wire the switch in the dash. I am using the Warn remote and its a pain in the ass! The wiring is very simple. 12 volts to the center terminal on the switch and one wire to each outside terminal of the switch to each side of the contactor.
Note: The toggle switch needs to be a momentary Single pole double throw momentary center off. You could use a maintained center switch off however it's too easy to forget and leave it on.
PostPosted: Thu Jul 09, 2009 5:51 pm
the remote on my winch messed up so i used a 3 way toggle switch, but when you mount it, make sure the passenger can reach it.
PostPosted: Thu Jul 09, 2009 6:56 pm
you got that switch in the same place as your super duper time warp extra fast ludacrist speed button.lmao.chad
PostPosted: Thu Jul 09, 2009 11:04 pm
i put the super duper time warp extra fast ludacrist speed button away from the passenger so they dont hit it by accident thinking it is just a cigarette lighter. :lol: :lol: :lol:
dave
PostPosted: Fri Jul 10, 2009 2:42 am
well guys what gauge wire did ya use? will 10 gauge work on it ?
Brandon
PostPosted: Fri Jul 10, 2009 5:30 pm
Your winch should have two selinods built into it. It doesn't take too many amps to power up the selinods. So you don't have to go 10 guage, you can go 12 or 14. I'd go about 12. As far as mounting the switch so your passenger can get to it, on more than one occasion, I had to get out, and have the passenger run the winch while I pulled the cable uphill and tied it to a tree.
Dave
PostPosted: Sat Jul 11, 2009 12:27 am
well thanks guys i got a roll of 25feet 10 gauge cable so i'll use that
Brandon
