It is currently Sun May 03, 2026 5:45 pm
 Post subject: Ciol Over Shocks
PostPosted: Fri Feb 01, 2008 8:29 am
Saw this and figured I would post. This is a good deal for the right application.
http://www.thesamba.com/vw/classifieds/ ... ?id=563108
PostPosted: Fri Feb 01, 2008 9:44 am
Seen those, to bad they are only 8" travel or I would have them on my buggy lol.
PostPosted: Fri Feb 01, 2008 10:32 am
With the correct mounting position, you could easily use them on the front. Creative mounting position or a custom made trailing arm.
PostPosted: Fri Feb 01, 2008 12:50 pm
I agree that you could mount the lower shock mount farther up the trailing arm or mount the top of the shock lower on the beam etc. I have a set of new Tweeds arms and a new 6 over beam w/10" towers and chose not to modify them to use the 8" coil overs that came with the Buggy. So I decided to sell them with the old front end and go with 10" shocks instead..
PostPosted: Fri Feb 01, 2008 8:27 pm
Ody what kind of shocks are you going to run?? Thanks Dave T
PostPosted: Sat Feb 02, 2008 12:02 am
I may go with FOX 2.0 Air shocks however money permitting Im leaning more towards FOA coil overs.
PostPosted: Sat Feb 02, 2008 9:56 am
Let me know if yo want the Fox Shox Dave T[img][img]http://i119.photobucket.com/albums/o157/silversandoffroad/Sep0508.jpg[/img][/img]
PostPosted: Wed Feb 06, 2008 8:26 pm
You'll need to be very careful when moving the shock mounts with coil-over or any suspension shock. To far in towards the main pivot and your spring rate goes way up and there are interference issues and the shock angle to the arm will be way off at full bounce. Too far away from the main pivot your spring rate will soften up a bunch but you'll need more shock travel and there could be interference issues as well with your radius rod or tie rod link. Use a spring rate calculator to help adjust the posisition.
PostPosted: Wed Feb 06, 2008 10:31 pm
And of course there are the technical reasons I dont want to do it lol.
