It is currently Sun May 03, 2026 5:45 pm
 Post subject: Extended trailing arms.
PostPosted: Tue Dec 11, 2007 9:11 pm
Hill Climber
We build a great looking lightweight and extremely tough trailing arm. These arms are built to be used in the woods, the most abusive type of buggy riding there is. They will also work well and look great on any buggy or Baja.
These arms are built using laser cut parts to insure consistent quality and are professionally welded. We use Precision Alloy Ltd. bearing carriers and pivots for the construction of these high quality parts. The design of the arm allows you to place disk brake calipers on top of the arm to help prevent damage to brakes by hitting trees and rocks. Or you can use stock drum brakes.
If you manage to brake or bend this arm I will replace it at no cost.
We can build stock, 3x2, 3x3 or 3x5
See trailing arms tab on the homepage.
Any questions contact me. Or call 419- 618-1307 and
or email Dean@woodsbuggy.com
PayPal accepted
PostPosted: Sun Jan 13, 2008 2:11 pm
give prices on 3x2's and 3x3's please.
Phillip
PostPosted: Mon Jan 14, 2008 12:30 am
im in need of some 2x3 as well
