It is currently Sun May 03, 2026 10:16 pm
 Post subject: Need 15 5/8" axles
PostPosted: Fri Jun 01, 2012 1:53 pm
Does anyone have a pair of 15 5/8" axles you don't need and are willing to sale?
 Post subject: Re: Need 15 5/8" axles
PostPosted: Fri Jun 01, 2012 3:10 pm
sorry i don have any axles but you have a great looking build
PostPosted: Fri Jun 01, 2012 3:26 pm
I have some for 930s
PostPosted: Fri Jun 01, 2012 4:27 pm
I will be using them with Type 2 CVs. I found out Tuesday just how high geared an auto tranny is. Time to convert to bus. Any pointers are welcomed.
Thanks for the compliment on the build.
PostPosted: Sun Jun 03, 2012 12:21 am
you use the same axles for the bus transmission as the car just have to change the joint
PostPosted: Sun Jun 03, 2012 9:10 am
Are you positive? Everything I read says the 002 bus tranny is a little wider than car tranny, which results in using the 15 5/8" bus axles with type 2 cvs and bus to car axle stubs. That is of course using stock size trailing arms. I never have done this so I'm trying to gather info. I just want to be sure. Thanks for your input. It makes me think more.
PS. I previously said using auto tranny. I meant car tranny. :roll:
PostPosted: Sun Jun 03, 2012 8:05 pm
You are correct, SAW offers these axles typically for street guys with stock trailing arms and a bus trans swap when the suspension travel is not more than stock. The problem with these offroad is that the CV angle increases more when the supension travel is increased and the CVs aren't happy. Have you considered Sawerybuilts with stock bus axles? It's a pretty good value for the money spent. JMHO
PostPosted: Mon Jun 04, 2012 8:38 am
What stubs you using??
I ran a bus with type 1 stubs and car axle 16.25 at 16/18 deg. For 2 years. Never had a problem on or offroad.
I changed my stubs to type 2 over the winter and running around 20deg. Still no problem but I do get some clicking some times when I back up so I to will be looking for the shorter ones. But it will work I have been to DTOR 2 times this year and around 1000miles on the street.
PostPosted: Mon Jun 04, 2012 3:11 pm
I am running a car tranny right now. I forget what the degree is on the axles but it is maxed out but not over that is recommed for a car cv. I just notched the spring plates a little. I just ordered a 002 tranny. So i have bought nothing yet. I think I'm going to get laid off work. So need to go cheap. Running a 1641. Its just a woods buggy. No radical hill climbing foreseen.
I have not seen or heard of Sawerybuilts. I googled it with no findings.
PostPosted: Mon Jun 04, 2012 6:23 pm
It's a guy that makes and sells arms on here.
No sure about stock size but I know 2x3 and 3x3.
PostPosted: Sun Jun 10, 2012 11:47 am
Bump
PostPosted: Sun Jun 10, 2012 9:06 pm
Ive got some. Ill have to dig them out tomorrow an ill get a pic if ur interested.
PostPosted: Sun Jun 10, 2012 9:08 pm
You havent had any problems because your running those skinny tires. You put some big v cleats on there I guarantee you break cv's and axles with ecotec power. Been there done that.
PostPosted: Sun Jun 10, 2012 9:30 pm
I'm planning on running type 1 stubs to type 2 cv. Stock trailing arms.
PostPosted: Sun Jun 10, 2012 11:28 pm
PM sent to ImmortalSoul219
PostPosted: Tue Jun 12, 2012 9:09 pm
pm with pics
PostPosted: Fri Jun 15, 2012 11:21 am
I got two pair one new and one used call me let's do some dealing 2563663727
Eddie~n~Sarah
PostPosted: Sat Jun 16, 2012 4:05 pm
I found some. Thanks for all the replies and info.
Now I need some 930 cv's. (yes, I went with 930 axle.s)
PostPosted: Sun Jun 17, 2012 11:49 am
ive got a set of those too
