 Post subject: babychain drive for sale
PostPosted: Wed Dec 09, 2009 8:05 pm
http://cgi.ebay.com/ebaymotors/Chain-Dr ... 2ea9bd2b89
PostPosted: Wed Dec 09, 2009 8:15 pm
That was the first cd .That is the same thing Buggymethis has he just has a punch-buggy on top.
PostPosted: Wed Dec 09, 2009 8:42 pm
yea,the rear end looks jus like his
PostPosted: Wed Dec 09, 2009 8:50 pm
I think it is a little bit different from Buggymethis trailing arms ,,but that is cool,,I like the in board calipers,,,that should make braking better,,,I have thought about the inboard,,or rather leading sprocket rotors but I dont have the room. That 1.8 Suby was my first suby engine too and my dad still runs it in one of his beetles. It is a very dependable engine,,about 80 hp.. Those A-arms look very doable in my future,,,,maybe :wink:
PostPosted: Wed Dec 09, 2009 10:35 pm
Looks Cool. Only one problem I see with inboard brakes. If chain or sproket fail you will not have any brakes. I like my brakes on the wheel.
kydecoy
Work Hard Play Harder
PostPosted: Thu Dec 10, 2009 9:07 am
do you thank those front a/arms, were built using ball joint spindles?
PostPosted: Thu Dec 10, 2009 9:09 am
That is exactly what it looks like. :idea:
PostPosted: Thu Dec 17, 2009 11:29 am
Use bus spindles and bus ball joints very affordable
If you put the rotors in board on a CD like mine, I think you could use a set off the front of a street bike calipers and all.Threw the chain drive you will need 1/3 the amount of brakes you will need at the wheel. And as far as breaking a chain ,if you do you will still have one rear plus the 2 fronts tires braking . Like the monster trucks they have a wilwood calipers like on my buggy ,but they are using it before the gear reduction like a skidder . Thinking about trying something like this my self
PostPosted: Tue Dec 29, 2009 5:29 pm
is this still for sale
