| My Bada** buggy http://woodsbuggy.com/phpBB3/viewtopic.php?f=6&t=6452 |
| Author: | nickschlemer [ Thu Apr 30, 2009 5:34 pm ] |
| Post subject: | My Bada** buggy |
Well, ive had no takers on my buggy. Lots of lowballers of course. So this is one last post before i part it out. Someone make me a resonable offer or its getting parted out. Thanks woodsbuggy for all the info in the past. Nick |
| Author: | Stevo [ Thu Apr 30, 2009 5:37 pm ] |
| Post subject: | Re: My Bada** buggy |
Mabey its a hint to keep it! But if you have to part it out I'd be interested in the half shafts, for the right price that is. |
| Author: | fortydegnorth [ Thu Apr 30, 2009 6:00 pm ] |
I might be interested in the wheels if you part it. If you decide to go that route send me the dimensions including backspacing. |
| Author: | nickschlemer [ Thu Apr 30, 2009 8:09 pm ] |
Fronts are 15x5 with Maxxis mudders buckshots 245/75/15 i believe regular offset Rear are 15x12 minimum offset like 3.5" with Boggers 31/12.5/15 Everything is all brand new never ran or cut And the half shafts i paid $1600 for them there also brand new and jet or ceramic coated 930 setup I have no choice but to sell it. My ole ladies laid off im getting my hours cut and family comes first. |
| Author: | nickschlemer [ Thu Apr 30, 2009 8:13 pm ] |
Rims and Tires Douglas 15x5 Front rims w/beadlocks Maxxis Mudder buckshot tires 235/75/15 Douglas 15x12 minimum offset rear beadlock rims w/Boggers 31/12.5/15 Shocks Front 2- Fox Shox Coil-over w/reservoir 12 inch travel and hypercoil springs Rear 2- Fox shox Piggy Back reservoir with 18 inch travel and hypercoil springs 2 front shock billet spring dividers 2 rear shock billet spring dividers 4 billet shock reservoir tube mounts 2 Fox bumpstops with mounting sleeves 2-24” limit straps 2 spring loaded limit strap mounts Seats 2 Corbuea with chrome belt hoop inserts 2 sets of Crow 5 point harnesses with crotch strap Brakes Front Pro-am sportsmens hubs w/ 2 piston calipers and vented rotors Rear Gear-one micro stub set up with 4 piston calipers Eagle performance front beam with long travel coil over shock towers Front Eagle performance front trailing arms 4x1.75 woods spindles Rear Eagle performance 4x5 trailing arms w/micro stub set up, shock mounts and inner pivots Pedals CNC Throttle pedal w/foot rest CNC dual tall reservoir w/quick cap brake pedal ¾ bore CNC single reservoir w/quick cap clutch pedal ¾ bore CNC slave cylinder w/slave saver kit (blue) Billet sliders for all pedals Summit 12 gal fuel cell with foam baffling (aluminum) Steering Grant steering wheel w/horn and quick disco Tilt steering box Power steering Sweet servo Howe ram Howe pump w/pulley Pro-am power steering reservoir w/filter Misc. steering shafts and U-joints already together (sweet) Heavy duty tie rod w/high misalignment hiems Saco heavy duty magnum rack Misc power steering and hydraulic lines and fittings Guages Autometer 2” Gas guage Autometer 2” cylinder head temp Autometer 2” oil temp Autometer 2” oil pressure Autometer 2.5” Voltage guage Autometer 3.5” speedometer and sender Autometer 2” Gas guage w/sender Pro-Comp 6834 monster tach fully programmable Aluminum Radiator Chrome radiator overflow Chrome radiator flex hoses with ends Misc. 4 chrome front beam mounting brackets 2- 1.5” billet tube ends or end caps Chrome battery box (summit) Braided brake and clutch lines 36” line stainless braided 30” stainless braided line 2 42” stainless braided lines 2 84” stainless braided lines 114 stainless braided lines 6 mini lazer star lights w/caps Misc. tabs and gussets Interior 2 Oh shit grab bars billet 1 adjustable oh shit bar billet 1 billet foot rest bar 1 double rise aluminum center console 1 billet switch box Transaxles 091 Don Johnson built bus box with stargazer powder coating Pro-am shifter very nice 091 case empty Kennedy stage 2 clutch w/kushloc disc and heavy duty throwout bearing Chrome hi-torque starter Frame Berrien Venture frame with custom torsion, custom tranny upper and lower mounts, diamond tread floor with wing trunk. Motor 2.5 Outback built Subaru Pierburg super quiet fuel pump and secondary filter Stinger EMS computer New wiring harness (nice) 330 HP Every bolt on available except scoop. K+N breather system All AN lines and fittings. So thats what i have to sell |
| Author: | nickschlemer [ Sun May 03, 2009 1:53 am ] |
Anyone wanna make some real offers? |
| Author: | moondog [ Sun May 03, 2009 4:56 pm ] |
is the switch box made for the roof? interested in it and gas and speed gaugeswith sendin units mayb all the gauges 4 right price |
| Author: | moondog [ Sun May 03, 2009 4:57 pm ] |
friend of mine interested in wheels and tires what lug pattern r they how much |
| Author: | Baddvw [ Sun May 03, 2009 10:34 pm ] |
PM sent |
| Author: | buggymaster [ Mon Jun 08, 2009 3:30 pm ] |
what do u want for the 2 buckshots or boggers |
| Author: | eggman [ Mon Jun 08, 2009 4:18 pm ] |
I am interested in the 235/75/15 front tires. Are they on a vw wide 5 pattern? How about pming me a cash price for the tires? |
