It is currently Mon May 04, 2026 5:23 pm
PostPosted: Sun Nov 09, 2008 9:54 pm
Frame:
Stock other than raised wwosheild and new tree bars ( I is bent) shock mounts on frame, I'd guess it's about 10 years old
Motor:
2300 cc pinto
91 Ranger roller head
Dual 36 mm Delarto Carbs
Esslinger Wtake
Esslinger Header
Esslinger Power Pulley
New Esslinger Bullet 2 pieces aux shaft
New Motorcraft Dist.
New Pertronix Ignigter
New Holly Blue Fuel Pump
Fuel Pressure Reg.
All A-N Fuel Lines and Fittings
High Torque Starter
SuperTarp
Rear Suspension
Sway Away 14 in. Stroke 1 3/8 Shaft Nitro Shocks
2 x 3 Trail wg Arms
Dual Spring Plates
Bead Locks
33 x 14 Cut Boggers 85%
Front Suspension
6 in over stock beam
RS 5000 Shocks
Stock Spinders Raised 2in and Plated to the max
31 In Tractor Tires
Steering
All New
SACO Rack
Heim Joint tierod ends 5/8 Shank
1 1/4 in. HEX Bar Tierod
3/4 HEX bar sieering shaft
New V-Joints on steering shaft
Misc.
New Die Hard Battery
BTM Shifter
CNC Cutters
CNC Peadls
Roof Rack
Two Tool Boxes
Mounts for Hi Lift
6 RIB Trans (KWDA Tired)
Bus To Bus CUS
Rear Nissian Disc W braided lines
please call with any questions
Kris
513-371-3879
$3800 O.B.O
PostPosted: Thu Dec 25, 2008 1:32 pm
any tradeS???
Don't let out when in doubt!!
