It is currently Sun May 03, 2026 8:48 pm
 Post subject: 2 seater for sale
PostPosted: Fri Sep 11, 2015 4:02 pm
After alot of debate ive decided to sell my buggy. Here is a run down of it
2 seat high top invader frame
2275.. fresh build with roughly 15-20 hours on it (very healthy motor with all the goodies)
Stock 6 rib trans w/ 4 spider diff
Rear tires are old school gateway "Q" buckshots (36").. cut 90% tread
Fronts are 31" buckshots that have all the outter lugs trimmed off (like a single rib)
Chevy brakes
3X2 rear arms
Sway away axles and bus cv joints
Hi-torq starter
Between work, family and other hobbies i just dont have the time to devote to it like i used to. Buggy is turn key, ready to ride
$6500
Pics coming soon
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
 Post subject: Re: 2 seater for sale
PostPosted: Fri Sep 11, 2015 4:24 pm
Ill give a run down on motor parts since that is where most of the money is
Small stud VW case
Cb 82mm crank (vw journal)
Cb 5.5 h beam rods
94mm mahle pistons and cylinders w/ total seal rings
110 cam w/ steel on steel straight cut timing gears
Scat hi rev lifters
Mellins oil pump
3/8 chromo push rods
Cb ultra mag heads... 42x37.5 SS valves w/ titanium retainers and locks... dual valve springs
Scat 1.25 ratio rockers
Dual 40mm dellorotos w/ tall scat intakes... everything match ported
20/50 VR1 oil and wix filter
Electronic ignition and blue coil
NGK plugs
Kennedy stage 1 plate and 4 puck disc
Built strictly for race gas.. very reliable and runs like a sewing machine with great power on tap
PostPosted: Sun Oct 11, 2015 12:16 pm
Bump... obo
Im not very tech savy so if someone could post pics for me ill be glad to send them to you
Brett-205-369-9956
