It is currently Sun May 03, 2026 11:49 pm
PostPosted: Tue Jan 27, 2015 4:31 pm
Located in Fort Worth Texas
1200 lbs. street legal buggy.
Titled as a 1974 bug, vin number is stamped into the frame, passes inspection as is
Professionally built 1641 dual port engine with an engle 110 cam
Redline Weber IDF 40. Bought and setup by the guys at http://www.aircooled.net
http://vwparts.aircooled.net/Single-Weber-IDF-Carb-Kit-All-Engines-Redline-p/redline-single-idf.htm
3x3 extended trailing arms. Custom fabricated kit from Avery's Aircooled
Polished high angle GNK Porsche 930 cv's
Sway Away axels
Sway Away rear torsion springs or airbags (*Is fitted for airbags, but not currently on)
FOA long travel shocks
Limit straps
Suspension seats (Race trim)
Turning break
6" over front beam with dual adjusters
3 rib bus transmission
Drum brakes on all 4
Crow 5 point harness's
Empi removable thru-shot silencer
Bright Hi/Lo beam headlights
Plastic no-rust gas tank
Brand new Mickey Thompson Mini Mac's on the front, and BFGoodrich's All terrain TA/KO's on the rear
Dune buggy has a t-trailer that comes with it, and some spare parts. (Will add pictures soon)
$5250 obo.
Will accept partial trades for:
18 foot bumper pull car hauler, 15', or 16" Bilstein/FOA/FOX/King shocks. A waterproof sound system for an crawler, 40" or bigger crawler tires for 16.5 rims, or if other sized wheels need to include 8x6.5 beadlocks.
*Images getting cut off here's the album http://s1381.photobucket.com/user/manther1/slideshow/Buggy
This thing is a blast to ride around town in. No problems except one rear rim has a little wobble to it. Can be repaired.
Sitting on an incline, thus the lean.
PostPosted: Wed Feb 04, 2015 1:39 pm
Fitted for airbags or torsions. Also shock bodies are threaded, so you could do coilovers instead if that what you want.
