| buggy for sale on ebay,16" travel a arms, 6 rib, 1915 http://woodsbuggy.com/phpBB3/viewtopic.php?f=6&t=16098 |
| Author: | adrelin [ Wed Oct 02, 2013 6:17 pm ] |
| Post subject: | buggy for sale on ebay,16" travel a arms, 6 rib, 1915 |
rail buggy, vw based, A arm suspension 16" travel Item Id: 231066520299 Starting price: $3,000.00 End time: Oct-09-13 08:35:15 PDT rail buggy, long A arm front suspension 16" of wheel travel, FOA dual spring/rate coilovers front/rear, rack and pinion steering, steering quickener reversed, 4 wheel wilwood disc brakes, CNC steering brakes with front/rear locks/cut offs, hydraulic clutch, metal body, padded buckets with 4 point harnesses, 091 6 rib/4spd tranny with superdiff, 930 conversion with HD high angle joints, 3x3 axles, tubed trailing arms, 1915 motor with single weber carb 40, oil tank with cooler/fan, 30" front tires, 33" TSL super swampers with 32 beadlocks/tubes, ridiculous ground clearance, everything is new, the bad; front nose of frame tweaked but is still useable, have used it awhile this way, engine has a miss from a plug wire that got burnt/fouled plug, engine still starts runs fine, may get that fixed before auction ends over 12k in build located in knoxville, tn pick up only ! |
| Author: | gasman [ Wed Oct 02, 2013 6:19 pm ] |
| Post subject: | Re: buggy for sale on ebay,16" travel a arms, 6 rib, 1915 |
Lol, I just seen that on eBay myself 5 minutes ago. Chad |
| Author: | ericP. [ Thu Oct 03, 2013 11:53 am ] |
i saw that on C-list. 3k was his asking price! |
| Author: | adrelin [ Fri Oct 04, 2013 10:47 am ] |
i had it on clist for 6k, then a make offer ad its on ebay started bidding at 3k......no reserve |
| Author: | ericP. [ Fri Oct 04, 2013 11:43 am ] |
sorry bout the misinformation. wasn't trying to put your buggy on half-price sale! |
