It is currently Tue May 05, 2026 4:06 am
PostPosted: Mon May 20, 2013 12:09 pm
I am looking to get into a good 2 seater. I would prefer not to have a fixer upper. I live in northern kentucky. Let me know what you have. Thanks
PostPosted: Mon May 20, 2013 3:04 pm
yea spend a little extra up front, saves you a lot of head aches down the road. so wither you buy AC or WC. buy something that is running and running well.
it all depends on your wallet, and what you can spend up front.
so good luck and check on here there are several on here for sale.
PostPosted: Mon May 20, 2013 9:57 pm
1st off welcome to the site.....
As for the buggy, can you give us a few details as to what you are looking for..
Water Cooled or Air Cooled?
Are you looking to Climb BadAss hills or trail ride?
How much are you looking to spend?
Here is what you can expect
--> $3K - $4K Mostly Stock Buggy with a few mods
--> $5K - $6K Upgraded Engine & Trans with Extended Arms and disc brakes
--> Over $7K High Performance Stoker with lots of Mods..
Before you buy ANYTHING, I strongly recommend you post the buggy on here for opinions..
Good Luck
PostPosted: Tue May 21, 2013 10:32 am
I found one that I am going to look at today let me know what you guys think. http://cincinnati.craigslist.org/cto/3815691499.html
PostPosted: Tue May 21, 2013 11:24 am
It looks nice but I've seen it on Craigslist for months. At least since late Fall or early Winter last year. Maybe it's priced to high or not that great up close. Looks good in the pictures and the specs aren't too bad for the money. It's listed in Ohio and Northern Kentucky so I'm not even sure where he has it. Probably worth a look I'd say.
PostPosted: Tue May 21, 2013 11:45 am
Drive down here and I've got a solid short rail with car tanny. Everything but a motor 600.
PostPosted: Tue May 21, 2013 12:08 pm
I have seen it on there since I started looking in april. I talked to the guy last night and he said it was in Alexandria, Ky. I am not an expert on these rails, is there any warning signs or specific things to look for when I go see it.
PostPosted: Tue May 21, 2013 1:27 pm
Im in trussville alabama i have a invader ready to ride with a 3 rib bus tranny and a stock 1600 with boggers that have less than 5 rides on them that i will sell for 1500 i wouldnt spend 5 grand on that buggy
PostPosted: Tue May 21, 2013 2:30 pm
Alabama is a long ways away
PostPosted: Tue May 21, 2013 5:58 pm
I have a 96" wheel base Beeline for sale. Has New boxed 2x3 rear trailing arms. with new limit straps. new calipers new bus axles. Has bus joints on both ends. 3 rib bus Brand new 40mm duel empi carbs. Less than 2 tanks of gas ran threw it. Has 4 ply firestone tires with steel beadlocks. Brand new alternator. runs like a top! needs nothing. Also has new V tread tires on front. Can call or text for pics. 8593391396. I can text pics. thanks. Matt. Located south central ky 4500 firm!
PostPosted: Tue May 21, 2013 7:30 pm
I might as well jump in .
Beeline cobra frame yellow
fiberglass body kit black
Disk brakes on all corners
3.1 liter GM v6
Weedle aftermarket 1st through 4th gears, superdiff, 5 rib tranny, 4.86 r&p
6x6 trailing arms
930 cv's and axles
4ply firestones on steel beadlocks
Scary fast
New 6 puck clutch, stage 2 kennedy pressure plate
Power steering
$4950
PostPosted: Wed May 22, 2013 9:05 am
Stillwell1 I know somebody looking for buggy send me your number or call me 1-662-two three one-1389 thanks
PostPosted: Wed May 22, 2013 3:13 pm
3.1 liter GM v6
6x6 trailing arms
930 cv's and axles
Scary fast
Power steering
$4950
I'd like to see this sob
PostPosted: Wed May 22, 2013 5:31 pm
3.1 liter GM v6
6x6 trailing arms
930 cv's and axles
Scary fast
Power steering
$4950
It's the one in the middle.
PostPosted: Sat May 25, 2013 9:34 pm
I'm in florence come check my rail out. For 3500 you really can't beat it. Has lots of mods. Hit me up come check it out. 8594449658
PostPosted: Thu May 30, 2013 1:55 am
I have a nice beeline cobra (I think) it's a 2009 shop model with a 1915 and a 6 rib i dont get on her much anymore so e-mail me for more info if your interested live_2_crash@rocketmail.com
thanks
PostPosted: Sun Jun 16, 2013 7:23 pm
Got a really nice avenger with well built 1915 and built 5rib asking 4500 Obo I can send pics my number is 304-216-4613
cron
