It is currently Mon May 04, 2026 1:23 am
PostPosted: Wed Apr 11, 2012 1:44 pm
Vw rail with 2276 dual dellorto carbs, alternator with serpentine pully kit, electronic ignition, chrome shrouds, has bus front end with tall shock towers and bus steering box, disk brakes all the way around, car torsion rear with extended 3x3 trailing arms, dual rear shocks, has 5 rib bus transmission that has been completly rebuilt with all weddle gears, it also has a stick-o-matic bellhousing that allows it to idle in gear, aluminum fuel tank, cutting brakes, lights front and rear, cb radio, could be made street legal easily, front tires are single rib tractor tires, rear tires are cut Q buckshots, rear end set up by Clarence Hampton in cleveland tennessee, has full fiberglass removable skins, windshield, very well built from the front to the rear, poly seats with 5 point harnesses, $5500 770-540-6571
