It is currently Sat May 02, 2026 10:51 pm
PostPosted: Mon Oct 05, 2020 11:17 am
An original ChainDrive Railbuggy. One of Benard Burns.
-Custom built Trailer included
-It has a VW 2276 with a stroker crank (82mm Throat crank) bored to 94mm cylinders.
-Heads are milled out.
-120 engle cam.
-45mm Delortto carbs.
-6 rib transmission has 5.42 ring and pinion gear.
-VW Hi-performance torque starter.
-Wilwood Racing Calipers with CNC master and cutting brakes.
-Disc brakes all the way around.
-Steel braided brake lines
-Power steering is from a 94 Chevy Beretta.
-A-arm front end with Pro Formance coilover shocks all the way around.
-All wheels are steel
-2 sets of rear wheels and tires
-42" cut & grooved super swamper TSL's and 40" cut & grooved bolted super swamper TSL.
-Plexiglass side panels for in closure
-Battery is new and kept on maintainer
-lots of extras (heim joints/sprockets to name a few)
NO TRADES
Contact Chris at 770-468-8850
PostPosted: Mon Oct 05, 2020 12:55 pm
I'd like to add photos but apparently there's issue's with uploading attachments to my post. If anyone wants to see the buggy, pm me and I'll get back with you.
