| my grenade!!! http://woodsbuggy.com/phpBB3/viewtopic.php?f=5&t=9304 |
Page 1 of 2 |
| Author: | bmoore [ Sun Apr 18, 2010 10:10 pm ] |
| Post subject: | my grenade!!! |
| Author: | purplerail [ Sun Apr 18, 2010 10:12 pm ] |
| Post subject: | Re: my grenade!!! |
is that off the yellow buggy?? |
| Author: | bmoore [ Sun Apr 18, 2010 10:12 pm ] |
cam broke behind the gear and man did it make a mess |
| Author: | bmoore [ Sun Apr 18, 2010 10:14 pm ] |
purplerail wrote: is that off the yellow buggy?? unfortunatly yes it is |
| Author: | vw_brandon [ Sun Apr 18, 2010 10:14 pm ] |
damn, what size motor was that? |
| Author: | purplerail [ Sun Apr 18, 2010 10:15 pm ] |
it sounded good on the first run |
| Author: | bmoore [ Sun Apr 18, 2010 10:19 pm ] |
vw_brandon wrote: damn, what size motor was that? was a 2180 |
| Author: | pipedope [ Sun Apr 18, 2010 10:23 pm ] |
Glad to get to meet you hate that you blew up. Hope you get it fixed befor the next climb. |
| Author: | JeffClay [ Sun Apr 18, 2010 11:01 pm ] |
that sucks, my last motor did about the same thing, rod nut screwed off then it bent up like that and broke cam and everytihng else. make sure you buy h beams with the arp bolts next time, worth the extra money for sure. good luck getting a new one together! |
| Author: | bmoore [ Sun Apr 18, 2010 11:19 pm ] |
pipedope wrote: Glad to get to meet you hate that you blew up. Hope you get it fixed befor the next climb. nice meeting you to pipedope! im going to do my best to have her ready! |
| Author: | bmoore [ Sun Apr 18, 2010 11:21 pm ] |
JeffClay wrote: that sucks, my last motor did about the same thing, rod nut screwed off then it bent up like that and broke cam and everytihng else. make sure you buy h beams with the arp bolts next time, worth the extra money for sure. good luck getting a new one together! thanks jeff! im looking at a suby |
| Author: | Dave Winterburn [ Mon Apr 19, 2010 2:36 am ] |
Were you using a dry sump system or stock oil pick up? I'm just going to use the stock pick up system my self but, I think I'll go back and loctite the nut holding the pick up tube in side the bottom of the sump. |
| Author: | racefreakj77 [ Mon Apr 19, 2010 10:49 am ] |
That's nasty ! If I can help in any way let me know. Need to get you ready for Memorial weekend @ Turkey Bay |
| Author: | Odyknuck [ Mon Apr 19, 2010 10:55 am ] |
WoW! Sorry to see that. I guess you really have a good reason to go Subie now. |
| Author: | Terry fryer [ Mon Apr 19, 2010 3:39 pm ] |
I hate to see that. Hope u get it back together soon. Just out of curiosity what brand cam was that? |
| Author: | turboblue [ Mon Apr 19, 2010 4:33 pm ] |
Looks like a rod bearing failure took out the rod which took out the cam. Seen that before.......... Shuffle pinned case too, what a shame. Your box of frame parts is on the way too Brandon. Thanks |
| Author: | hillaholic [ Mon Apr 19, 2010 4:34 pm ] |
damn that sucks. was it a fresh build? I'd be calling about that 2387 and 6rib for 4k. |
| Author: | hillaholic [ Mon Apr 19, 2010 4:40 pm ] |
http://www.woodsbuggy.com/index.php?opt ... 425#p78425 |
| Author: | nitro_mudder [ Mon Apr 19, 2010 5:30 pm ] |
Welcome to the dark side |
| Author: | gasman [ Mon Apr 19, 2010 5:36 pm ] |
well i hate to see its that bad but you give it hell,had one of the best wheelie's of the day in the event.did a great job for a 4-seater and no tree bars glad i finally met you in person now get it fixed and bring it to wellsville memorial day.chad |
| Author: | kevin f [ Mon Apr 19, 2010 6:26 pm ] |
My motor did the exact same thing, but I got lucky and it did it while at an idle. I had an engle 110 cam. One of the bolts that came with the cam failed. The head of the bolt sheared of flush with the cam gear. The head of the bolt got between the gears and broke the cam and blew a hole through the oil pump. |
| Author: | bmoore [ Mon Apr 19, 2010 7:55 pm ] |
turboblue wrote: Looks like a rod bearing failure took out the rod which took out the cam. Seen that before.......... Shuffle pinned case too, what a shame. Your box of frame parts is on the way too Brandon. Thanks thanks gary i appreciate it |
| Author: | bmoore [ Mon Apr 19, 2010 7:57 pm ] |
gasman wrote: well i hate to see its that bad but you give it hell,had one of the best wheelie's of the day in the event.did a great job for a 4-seater and no tree bars glad i finally met you in person now get it fixed and bring it to wellsville memorial day.chad thanks gasman it was good meeting ya'll |
| Author: | bmoore [ Mon Apr 19, 2010 8:01 pm ] |
it was a engle 110 cam but i think turboblue is write about the rod failing first. dark side here i come lol picking up a 2.2 suby |
| Author: | instigator [ Mon Apr 19, 2010 8:34 pm ] |
looks like you and gasman have the same engine builder! lol |
