It is currently Tue May 05, 2026 3:37 am
 Post subject: wellsville- labor day
PostPosted: Tue Sep 08, 2009 2:32 pm
So, i barley got my rail together. But i made it to wellsville and had a decent ride. My dad cracked his frame, just like i did on mine. I had a few issues on my rail when we got there. Lost a brake pad, and blew 2 cv's due to not having the back spacer for the stub axle, letting the rotor to be loose and same with the stub. But we fixed it and got some good rides.
My buddies 4x4. Its a warrior chassis on a early 80's fullsize blazer frame. Has a 350 mated to a 700 r4 tranny.
loading up to go......at almost 12! On saturday
dads rail
both top and bottom bars broke
Now. My new rail....
buddie teds rail
loaded to go
PostPosted: Tue Sep 08, 2009 10:37 pm
Look like you still had a good time. We stayed home. My frame cracked/ broke like that on at least on tube every time I pushed it hard.
These Five tubes stopped all that. An x brace
Two tubes to tie the x into the upper beam clamps.
Where the two tubes that tie into the front beam clamps come to gether you can also add two tubes from there down to the lower tubes just behind the tie rods where the vertical 1" tube meets the lower 1.5 " main tube. My battery box is in the way so I left them out.
The small tube gussets by the windshied kept the front hoop from cracking at the upper main tube.
PostPosted: Wed Sep 09, 2009 12:08 am
I hope your buddy NEVER rolls that 4x4 ! That warrior chassis will NEVER hold all that weight up when its upside down! It will crush like an empty beer can!! he needs more support in it!Very scary :shock:
PostPosted: Wed Sep 09, 2009 3:46 pm
trust me man, i know. im trying to get him into a rail
