It is currently Mon May 04, 2026 10:22 am
 Post subject: MadMike's Buggy
PostPosted: Tue Apr 17, 2007 10:06 pm
My first buggy build
PostPosted: Tue Apr 17, 2007 10:27 pm
some misc shots
PostPosted: Sun Apr 29, 2007 6:55 pm
even more
PostPosted: Sun Apr 29, 2007 9:14 pm
What kind of rims are you running on the rear? THey look just like mine,which are off a circle track car.If so,where did you get the adapters?I had a set made out of 1/4 " alum. and already bent them after 2 rides.
PostPosted: Mon Apr 30, 2007 12:39 am
Mike 1/4 is way too thin,,I use 5/8 6061 or 7075 Alum Mudd
PostPosted: Mon Apr 30, 2007 6:16 pm
Mine are 1/2" 6061 and I haven't bent them yet. I am only reducing my lug pattern down to the wide 5 VW pattern so they are not as big as the 4 lug adapters.
Looks really good Mike. Have you put that transaxle in yet????
PostPosted: Mon Apr 30, 2007 9:31 pm
The wheels are Dirt track Late Model wide 5. I made the adaptors out of 6061-T6, 3/4" thick at the minium. These won't break, or if they do I have bigger problems than that.
Not yet Roy, two more weeks. I need to get two sets of spindles and a set of arms done first. And thanx, it is comming together nice.
PostPosted: Tue May 01, 2007 1:05 pm
Looks sweet man! Nice ride.
-Blake
PostPosted: Fri May 11, 2007 9:13 pm
:) vw 2275 is the shit keep it simple and gat all the power you want it will gitter done over the top
virgil Image
