Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: my new t-arms
PostPosted: Mon Mar 03, 2008 1:30 am
i got 1 of them on but on the driver side i cant get that bolt in the front of the arm to slid out it is rusted to the metal sleeve in the bushing i think any ideay on what to do to get it out of there
PostPosted: Mon Mar 03, 2008 1:49 am
I`ve had to cut them with a torch to get them out of the sleeve,You can buy new bolts for it pretty cheap,just a suggestion.
aaron
PostPosted: Mon Mar 03, 2008 1:52 am
yea i think i have another bolt i was thinking of cutting it just checking to see if i missed a way to remove it if this happens but i guess i will just cut it i know i have 7 hours in to trying to get it out
PostPosted: Mon Mar 03, 2008 11:08 am
[quote='jesse']yea i think i have another bolt i was thinking of cutting it just checking to see if i missed a way to remove it if this happens but i guess i will just cut it i know i have 7 hours in to trying to get it out[/quote]
7 hours :eek: :eek: That thing would have lasted an hour with my patience and it would have been torched off :lol:
PostPosted: Mon Mar 03, 2008 11:19 am
did you get it loose or unthreaded if so barrow or buy a dent snatcher from habor fraight weld it to the bolt head hit it 1 or 2 times pretty hard it should come loose
(LIVE EVERY DAY LIKE IT IS YOUR LAST) AND AS I TELL MY 10 YEAR OLD BOY ANYTHING BROKEN CAN BE FIXED
PostPosted: Mon Mar 03, 2008 3:44 pm
i dont have a torch so i was just trying every thing i could but i give up im going to get my buddy to come cut it off
PostPosted: Mon Mar 03, 2008 4:14 pm
o and yea its unthreaded
PostPosted: Mon Mar 03, 2008 7:16 pm
I had the same problem before. I used a sawzall to cut the pivot bolt.
PostPosted: Mon Mar 03, 2008 7:19 pm
I too had a similar problem just the other day. My son welded a piece of rebar to it and made a makeshift "dent puller" and snatched it out..And when you go back together with it both of those big washers go on the outside :wink:
PostPosted: Mon Mar 03, 2008 7:46 pm
arms sure does look good
PostPosted: Mon Mar 03, 2008 9:07 pm
well now there is a new problem i got the old arm off but what happend is the bolt broke off where it is threaded in so there is still some of the bolt in the hole it threads into and u cant fit a drill in there so any ideas on what to do
PostPosted: Mon Mar 03, 2008 10:01 pm
Damn, that sucks Jesse. Never heard of it before but sounds like you have a pain on your hands. Good Luck with it. Could you use a 90 degree head drill to get into drill it out maybe.
The Wild Kids
PostPosted: Mon Mar 03, 2008 10:20 pm
How much broke off inside? And who's arms are thoes??
PostPosted: Mon Mar 03, 2008 10:58 pm
[quote='jesse']well now there is a new problem i got the old arm off but what happend is the bolt broke off where it is threaded in so there is still some of the bolt in the hole it threads into and u cant fit a drill in there so any ideas on what to do[/quote]well my brother had the same problem he heated up the broken bolt with map gas and took a punch or small chisel and carefuly tapped out the broken shank until he could get some pliers
on it.it worked well.iam getting ready to
RIDE HARD-PARTY HARDER
PostPosted: Mon Mar 03, 2008 11:45 pm
donie but i dont know his last name i went threw a guy i ride with but i believe this is who made them only $200 and 2 old arms. but the bolt broke off flush with the edge and is good and rusted in there so i dont think it is going to turn i will try the heat tomorrow
PostPosted: Tue Mar 04, 2008 2:27 am
soak it in wd40 then weld a nut to it and put a wrench on it.
PostPosted: Tue Mar 04, 2008 4:43 pm
it broke off flush so u take the chance of welding the bolt to the torshion
PostPosted: Tue Mar 04, 2008 7:00 pm
I had the same problem.what did is to make a 1 1/4x1 1/4x5/8 square nut tap it 7/8x14 cut out the broken bolt and the little nub that the arm sits on center nut in the square hole and weld in then use a 7/8 bolt. won't brake that bolt.good luck you can put the nut on the nub and trace it with a scribe and be realy accurate.hope this helps.ti took me almost as long to tipe this as to do the repare.
PostPosted: Tue Mar 04, 2008 7:15 pm
Who makes those??
PostPosted: Tue Mar 04, 2008 7:17 pm
here is a pic of it
and donnie hogland makes the arms
PostPosted: Tue Mar 04, 2008 7:25 pm
looks like a copy of deans arms.
to fix your bolt buy a weld in pocket and make a insert out of it
PostPosted: Tue Mar 04, 2008 7:44 pm
[quote='purplerail']looks like a copy of deans arms.
to fix your bolt buy a weld in pocket and make a insert out of it[/quote]
thats what I thought
PostPosted: Tue Mar 04, 2008 7:56 pm
im going to see what i can do tonight
PostPosted: Tue Mar 04, 2008 8:19 pm
If you end up drilling it, use a left handed bit.
John
