It is currently Mon May 04, 2026 10:22 am
PostPosted: Wed Dec 19, 2007 11:14 pm
PostPosted: Wed Dec 19, 2007 11:27 pm
how does that aqirfilter cover work does it get enough air and do you have a prefilter on the airfilter or not just curious trying to prevent the dirt problem
PostPosted: Wed Dec 19, 2007 11:29 pm
works great for me never had any dirt problems
PostPosted: Wed Dec 19, 2007 11:31 pm
cool thanks
better pick of the breather
PostPosted: Wed Dec 19, 2007 11:35 pm
now is that just a cartridge in a canister that is sort of what i would like to do to mine
PostPosted: Wed Dec 19, 2007 11:38 pm
it is a filter off a bobcat and the filter is in the black cylinder that is all the filter it has
PostPosted: Wed Dec 19, 2007 11:41 pm
thanks nice rail by the way
PostPosted: Thu Dec 20, 2007 12:18 am
Nice buggy!The guy that built those fugitive frames has to be a millionare thats is the only frame you ever see from AL he must have made a million of them,I like the way they look just not much head clearance.
aaron
PostPosted: Thu Dec 20, 2007 12:21 am
yea u lack head clearance but i put in layed back seats and i have plenty of room now
PostPosted: Thu Dec 20, 2007 8:30 am
That air cleaner is a good idea but it looks like you use some improvements with that hose. The dirt inside the pipe is an indication its leaking. Try some silicone hose off of a big rig turbo tube, works great. They have a good seal and wont let dust in. I'll try to post pics asap.
PostPosted: Thu Dec 20, 2007 9:27 am
Also don't make the same mistake I made. Use K&N spray on oil on the paper element. It will save you hundreds of dollars. 8)
PostPosted: Thu Dec 20, 2007 5:41 pm
I use dirt bike oil, It seems to stronger and cheaper. I spray it on the inside of the pipes too. You'd be surprized what gets past the filter!
PostPosted: Fri Dec 21, 2007 8:20 pm
ty for the advice will do
