It is currently Mon May 04, 2026 2:18 pm
PostPosted: Thu May 16, 2013 9:21 pm
http://akroncanton.craigslist.org/cto/3754160952.html
*subiepower*
PostPosted: Thu May 16, 2013 9:23 pm
sorry wrong thread
*subiepower*
PostPosted: Fri May 17, 2013 12:52 pm
I would shy away from this one. I have seen it and it isn't pretty. I did not see it run with the stroker but if the motor is piece milled like the buggy I would be very leery of it. I would not recommend it to a friend... and as far as I am concerned... anyone on here is a friend so I thought I would throw this out there.
PostPosted: Fri May 17, 2013 4:14 pm
looks pretty rough around the edges and I wouldn't count on the motor being anything other than the rest of car. One of the many instances you're merely taking someones word on internals unless they'd be cool with yanking a head off of it. I don't have a problem taking the time to disassemble top end if I was potentially interested! Does look like it has some decent parts, wilwood brakes, hyd clutch & cutter, T trailer. If it was closer to home I'd check it out, but don't wanna waste time/money/gas on driving that far for nothing
PostPosted: Fri May 17, 2013 6:21 pm
Let the buyer beware, enough said
PostPosted: Fri May 17, 2013 10:36 pm
i just thought with whats there for the money it aint bad and i thought the same about the stroker you can tell alot about someone the way they keep there stuff to do a stroker right aint cheap and buy the looks of it they dont cae to much about it my opnion anyway
*subiepower*
PostPosted: Sat May 18, 2013 12:18 pm
look at the pic of the pedals. you see the welds have cracked between the floor and the side. this by itself is not a huge deal but i would be highly concearned about the rest of welds on the car.
