It is currently Mon May 04, 2026 12:50 pm
 Post subject: Posting pic help
PostPosted: Thu Nov 01, 2012 8:21 pm
I have tried EXACTLY what it says under the topic of "posting pics" with Photo Bucket, Tiny Pic , etc. and I just can't make it happen!Heeeelp! :oops:
 Post subject: Re: Posting pic help
PostPosted: Thu Nov 01, 2012 8:49 pm
dave i will call you tomorrow and come over and show you how to if you will be around
PostPosted: Thu Nov 01, 2012 8:52 pm
Can you make it b4 noon. I'll be leaving for Fultondale at 1:30.
PostPosted: Thu Nov 01, 2012 9:19 pm
The easiest way I have found to do it is using a photo hosting site. I registered at http://www.photobucket.com and then sign onto their site. It will have a tab labeled "upload", click it. It will have a tab labeled "browse", click it. This will pop up a window that has folders and files that are on your computer. On my computer my pictures are stored in a file named "my pictures", this may be under "my documents" and then a sub menu. Click wherever your pictures are filed on your computer. The pictures should pop up. Click the picture you want, if you want more than one hold down the "Ctrl" button on the lower left of your keyboard while you click other pictures. This will select them. Click "open" or whatever it says at the bottom of the little window you are in. This gets them to photobucket. You need to click "upload" in photobucket now and they will be stored on their site. Now to get them to woodsbuggy you need to have woodsbuggy open and a post reply box up. Open a new window on your internet browser by pushing the "Ctrl" button on your keyboard and the letter "n" at the same time. A new screen exactly like your other will open. In the new screen go to photobucket. Click the picture you want and you will see a white box on the side of the page that has "image links" at the top. The fourth link down is "IMG code", click it and it will flash saying copied. Now click back into the woodsbuggy page and your reply box. Once in the reply box simply hit the right button on your mouse, or touchpad, and then hit paste. It will post a code like: IMG http://i101.photobucket.com/albums/m IMG. This is your picture in code form. Then just hit preview and see if it worked. If it did hit submit. Bam! You're done. :mrgreen:
PostPosted: Fri Nov 02, 2012 8:11 pm
You can also add them to the WoodsBuggy Photogallery
