 Post subject: My latest Baja build
PostPosted: Fri Feb 04, 2011 7:57 pm
This one is street legal and very off-road capable. I am trying to get the best of both worlds here but tires are always a compromise for street and trail.
 Post subject: Re: My latest Baja build
PostPosted: Fri Feb 04, 2011 8:43 pm
NICE WORK 8) 8)
PostPosted: Fri Feb 04, 2011 9:28 pm
Thanks! Still trying to come up with a good heater setup. Electric heaters aren't good enough.
PostPosted: Fri Feb 04, 2011 11:48 pm
nice job! looks great!
lets just ride
PostPosted: Sat Feb 05, 2011 12:31 am
I used to have a baja and had the same problem. I took an external oil cooler with a fan and installed it in the car. It worked great and in the summer time I mounted it outside. Just an idea.
PostPosted: Sat Feb 05, 2011 1:03 am
Got in
a baja once with a heater that ran off the fumes of the gas tank.They come out of a vw camper.You must drive with the windows down! :!:
PostPosted: Sat Feb 05, 2011 1:09 am
I'm going to try the oil cooler idea
PostPosted: Sat Feb 05, 2011 2:13 am
very nice ride
PostPosted: Sat Feb 05, 2011 3:02 am
I Want One :!: ... 8)
PostPosted: Sat Feb 05, 2011 7:00 am
:?: wouldn't long oil hoses rob press or volume?If you are wearing a warm monkey suit do you really think you will feel any benefit.Get a small green propane bottle at walmart with a small burner attached. I had one in my old type 3 baja. If you drop it it is designed to break for safety purposes or go out if it is turned over.It's made for tents.Secure it in the passenger floor board in an old milk crate.Turn it off while driving, I don't know.Crack your window for air.
PostPosted: Sat Feb 05, 2011 8:45 am
Subys have great heaters ,, and start on cold days. just an idea if you might think about WC,,if not that is cool
PostPosted: Sat Feb 05, 2011 2:09 pm
I thought about the drop in oil pressure too. I would mount it on th rear fire wall. guessing about 24 in. of oil hose in total but still have some reservations. I am running a heavy duty oil pump and when engine is warm i get 60 psi according to my gauge. Also this is the last vw engine I will ever build. They are getting way too expensive to build these days. After this it's going to be ecotech or subaru!
