It is currently Mon May 04, 2026 11:08 pm
 Post subject: avatar...need help!
PostPosted: Fri Mar 28, 2008 5:57 pm
Everytime I try to put my avatar (pic of my buggy) on the site it pops up and tells me something different like needs to be jpeg, gif , or 120 x 120 pixels. I have a resize program and have done all these things but it still wont let me put it up....I'm not real sharp on this thing but I've done this b4 without problems.....Can you help ?
Life is short.....Play Hard!
PostPosted: Fri Mar 28, 2008 11:28 pm
I guess nobody wants to help :(
PostPosted: Fri Mar 28, 2008 11:37 pm
Goto Tinypic.com, it is free....just upload your picture on the site and make sure that you are using the avatar mode on the resize category.....you will see. Then when it's done, click on the link that is under "Direct Link for Layouts" when you scroll the mouse on the link, a little box below it will pop up and it will say "Click to Copy" click on it once, leave the window open. Then open up another webpage, goto Woodsbuggy.com under "Profiles" click on it, then scroll all the way to the bottom of the screen to where it says "Link from offsite avatar" use the right click button on the mouse and a little window will pop-up, click on "paste" it will paste the link address on the line. then click on "submit", then you should be ready to go.
PostPosted: Fri Mar 28, 2008 11:40 pm
I have a similar program on my puter now, but will give this a try...Thanks for the help.
 Post subject: Avatar Help
PostPosted: Sat Mar 29, 2008 9:25 am
I posted a step by step procedure awhile back, if you look in the archives it should be there. Its pretty much what BaddVw said though, just make sure when you resize it at tiny.pic that you select avatar. Hope this helps.
Donnie
PostPosted: Sun Mar 30, 2008 12:16 am
Thanks guys ...I finally got it.
