It is currently Sun May 03, 2026 6:31 pm
 Post subject: rear suspension ?
PostPosted: Mon Aug 30, 2010 9:49 pm
I have a bee line single seater with custom torsion in it with adjusters. I have been to a few hill climbs and watching all the buggies that do well squat in the rear. I cant get mine to squat but about 2 inches I put 27 mm
torsion bars in it and have thought about changing to stock. I was just hoping for any thoughts on what to do because i dont think the buggy is climbing like it should. thanks for the input
 Post subject: Re: rear suspension ?
PostPosted: Mon Aug 30, 2010 9:54 pm
I use to run 27mm in my 2 seater and it was way to stiff even for the heavy 2 seater. I would go back to stock or 25mm.
PostPosted: Tue Aug 31, 2010 7:45 am
Stock is best. Set the torsion to where it sits up pretty good, but is still pretty squishy when you push on it. It may take 10 times of re-setting it, but it will work. Good luck!
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Tue Aug 31, 2010 9:09 am
Stock!! it may not have as much clearence, but it will work and ride much better!
PostPosted: Wed Sep 01, 2010 12:01 am
thanks for the input hope to them changed before the hill climb at d@k
