 Post subject: Heim ends
PostPosted: Thu Mar 25, 2010 6:06 pm
Ok I went with heim ends on my tie rods but I have 2 questions!!!
The heims I got did not have jam nuts on them. Are these just regular nuts that I can get at a hardware store?
What do I do were it ties to arm at the spindle do I drill the taper out to 5/8 and use a 5/8 bolt or is there ther a tapered specal bolt?
MoblMec
Tim
 Post subject: Re: Heim ends
PostPosted: Thu Mar 25, 2010 6:31 pm
You cannot get the jam nuts at the hardware store, you will need to get them from wherever you got the joints at and I drilled mine out all the way with 5/8" drill bit and use grade 8 bolt with nylocks.
PostPosted: Thu Mar 25, 2010 7:11 pm
well whatever brand those nylocks was didnt last long at wellsville :shock: lol,bet you carry a spare 5/8 bolt now.chad :mrgreen:
PostPosted: Thu Mar 25, 2010 7:13 pm
^^As above, we drilled our spindles out to 18mm though as we're using 18mm with top hats inserted to get enough travel.
PostPosted: Thu Mar 25, 2010 7:16 pm
I used to have regular nuts with lock washers at the time and now uses nylocks, that part sucks when the arm fell off the spindle :lol: :lol:
PostPosted: Thu Mar 25, 2010 7:18 pm
I used to nylock + locktite everything when we had the old veedub in, that thing used to shake bolts loose just from the engine vibes :lol:
I oughta have bought shares in locktite the amount of times this car's been apart....
got lucky one buggy out of 15 had 5/8 bolt and nut to fix it though at least we got you back on the trail lol.chad :mrgreen:
