It is currently Sun May 03, 2026 6:29 pm
PostPosted: Sat Feb 27, 2010 3:27 am
does anybody have the part #'s for the rear irs stub axle bearings and seals and also for the front kingpin wheel bearings and seals?
i was hoping to be able to go to autozone as they carry timken brand bearings or maybe oreilly's as they carry national brand bearings
also if anybody has a diagram for the rear setup i would appreciate it cause its been a while and i just want to make sure everything is and the previous owner didnt leave anything out
Thanks
P.S. correct me if im wrong but a 64 model beetle should cover the kingpin frontend and a 74 model beetle should cover the irs rearend and also the timken, national, fke, and fag are all good brands correct or are there any more?
 Post subject: Re: need part #'s
PostPosted: Sat Feb 27, 2010 9:28 am
front ( 30305 inner 30304 outer 224045 seal ) (rear 206 inner ma1206ef outer 1012 seal ) hope this helps.
PostPosted: Sat Feb 27, 2010 4:41 pm
what brand are those #'s for or will they cross to timken # set 1, set 2 and so on?
PostPosted: Mon Mar 01, 2010 9:28 am
timken/fedral mogal part# those are sets, and national seals
PostPosted: Mon Mar 01, 2010 2:53 pm
thanks
