 Post subject: My front suspension
PostPosted: Thu Jan 14, 2010 9:20 pm
Yo,
How is going folks. My names William. Im very new to dune buggies and stuff. I recently acquired a frame and it has a few issues, that I dont mind fixing. But one of the issues im having is that the front suspension is welded to the frame. Now, I would just leave it on there and go about fixing up everything else, but im wondering, what if this front suspension is really weak, and it breaks how will I remove it. But whats even worse... How will I put a new one one without any front clamps.
Like I said, Im very new too all this, and I may have allot of questions. The main reason why im here at this site is because I want to be able to do some serious off roading with my buggy. Similiar to what you folks do in yalls videos.
Maybe I should take a picture of what I have to give you guys a better idea of what im working with here. Ill take pictures in the morning or something.
 Post subject: Re: My front suspension
PostPosted: Thu Jan 14, 2010 9:40 pm
Nothing wrong with welded front beam that a sawzall can't fix. Mine is welded on and a few others are 2. A good bead of weld is lighter than clamps :mrgreen:
PostPosted: Thu Jan 14, 2010 9:51 pm
ahh good point!!!! So having it welded isn't nesscarily a bad thing?
PostPosted: Thu Jan 14, 2010 10:11 pm
I wouldnt worry about it unless you want powdercoat. If you have to cut it out its tuff to fix powder. Paints more forgiving to repairs.
PostPosted: Thu Jan 14, 2010 11:37 pm
a lot of ky single seaters are welded in i do believe.. and marty, you better not use weight as an excuse on your buggy! hahaha
PostPosted: Fri Jan 15, 2010 12:30 am
Did you say LIGHTER??? Turnin over a new leaf are ya 'bug?? :D
Lighter, cheaper, cleaner, stronger, easier to do, no clamps to go get, less crap to drag, no bolts to work loose.......
PostPosted: Fri Jan 15, 2010 2:11 am
That lighter comment was strictly for your benefit Jellydaddy,,, I gave up on losing weight when I hit 50 :oops:
PostPosted: Fri Jan 15, 2010 3:03 pm
I thought I was an old fart at 44.....Sheeeesh!
PostPosted: Fri Jan 15, 2010 4:42 pm
Welllll, thanks for lookin out for me ol' buddy. :D
You must be talkin about 50 rides, you caint be over 50 yrs. :wink:
