 Post subject: Side Panels
PostPosted: Wed Dec 16, 2009 6:17 pm
We put a new panel on a box van last week and have some left over .050" gauge aluminum. I was thinking about using this. I know a lot of guys use pzus fasteners (sp?), but does anyone just rivet theirs on to taps like a stock car? I want to put them inside of frame rails..
 Post subject: Re: Side Panels
PostPosted: Wed Dec 16, 2009 6:25 pm
i luv my side panels,pop rivets
PostPosted: Thu Dec 17, 2009 3:33 pm
I was planning on adding some to my buggy too. I was going to use insulated "P" style clamps with the rubber on them and some small bolts. That way no mounting tabs necessary on the frame, no paint damage, and no rattle. Cheap and easy.
These are what I'm using:
http://www.mcmaster.com/#3225t9/=4z2ue7
PostPosted: Thu Dec 17, 2009 6:57 pm
My yellow rail has vinyl ones with snaps like a tonneau cover. 6 years in the woods & I only put 1 hole in em.
I like them so much I was going to make red ones for the new buggy. That was until I found these wraps for IMCA late models on Ebay.
Now I have to go aluminum. I want to rivet as well. Should I tack 1/2"x1/2" angle to the tubing & drill that or did you guys drill the tubing?
PostPosted: Thu Dec 17, 2009 8:03 pm
Don't drill the tubing. No matter how tight the rivet seems it will always leak water into the tube. If drilled in the wrong spot it 'could' cause a starting point for a bend or a crack. I've never seen a failure due to a pop rivet hole but there is a first for everything.
The rubber insulated tube clamps work real good, I have my Lexan roof, OK umbrella held in place with them.
There just a pain if you want to remove the panel for cleaning up.
PostPosted: Thu Dec 17, 2009 9:43 pm
i never thought about the insulated clamps, thats not a bad idea... I was just thinking about welding small tabs and drilling them for the pop rivets... I didn't really think it would be necessary to remove the side panels, a hood yes. If I did, just drill the rivets out and pop new ones in quick...
PostPosted: Thu Dec 17, 2009 9:49 pm
I used Zues fastners on my Buggy and will never go back to rivets, screws etc.
Expensive, You betcha
Pain to Install , You Betcha
Being able to remove panels easyly to wash and or work on the Buggy, PRICELESS!
Now thats Buggy Mastercard right there. :mrgreen:
PostPosted: Thu Dec 17, 2009 10:32 pm
If you use Adel clamps you could use polished stainless buttonheads with brass wingnuts on the back for easy removal & good looks. Im considering this now. Id drill every couple inches all the way around the panel for looks. Only 10 or 12 would bolt to a clamp. The rest would be eye candy. I like eye candy. Im a detail freak....
I really like Dzus fasteners but I now have this picture in my head of a 100 polished buttonheads around the perimeter. OOOOOOOHHH!!
That would be worth the time to measure & evenly space them around the panel.
PostPosted: Fri Dec 18, 2009 4:33 pm
Has anybody beadrolled their panels? Did you fold over the outer edges & flatten them to smooth them or did you guys leave the sharp edges?
PostPosted: Sat Dec 19, 2009 8:46 pm
Here is what Berrien Buggy sells for 99 cents..
Here is the link, you will need to scroll to the bottom of the page.
http://berrienbuggy.com/569806d0.jpg
PostPosted: Sat Dec 19, 2009 9:25 pm
http://www.summitracing.com/parts/SUM-G1888/
Summit has a 10 pack for $8.95
PostPosted: Sat Dec 19, 2009 11:18 pm
59 cent each
http://order.waytekwire.com/productdeta ... %201/2%22/
PostPosted: Sun Dec 20, 2009 11:35 am
I rolled mine right on the frame with a deadblow hammer. Worked out well. Hard to get a better fit any other way.
PostPosted: Sun Dec 20, 2009 12:04 pm
Racebug & i Sheet metal brake bend as far as it will go then put bake in and smash whith dies or hammer & will did bead roll some. If you no a roofer there brake will work to
PostPosted: Sun Dec 20, 2009 3:52 pm
I was figuring on having to beat it to fit the frame at the edges. Did you fold & make your edges double thick or just hit the edges with a sanding disc?
I guess what Im trying to find out if anybody leaves the edge alone & gets cut on them. Is it worth the work folding all the edges or is it a wasted step?
PostPosted: Sun Dec 20, 2009 5:02 pm
Fold edges where needed its worth the time
PostPosted: Mon Dec 21, 2009 2:06 am
MadMike wrote:
Thanks for the link Mike! Lots of good quality goodies and damn good prices!
PostPosted: Mon Dec 21, 2009 9:38 pm
mudd mutt wrote:
If you use these, you will probably want to paint them so they do not rust. The other ones appear to be treated to prevent rust.
PostPosted: Mon Dec 21, 2009 9:47 pm
Check again. They are plated steel. Still only 59 cents, each.
PostPosted: Tue Dec 22, 2009 5:19 pm
try this on the clamps
- Sigmund Freud
- Antonio Meloni
