It is currently Sun May 03, 2026 3:37 pm
PostPosted: Wed Nov 18, 2009 10:52 pm
I know some of you guys are building your own extended KP arms, but is anyone building their own extended balljoint arms? I'd like to keep my BJ front end, but want longer arms. I was thinking about building a jig and making a set... any input would be appreciated. Thanks.
PostPosted: Thu Nov 19, 2009 11:31 pm
didn't you do this firebug?
PostPosted: Thu Nov 19, 2009 11:34 pm
I did it with bus ball joint arms,,I am having a little trouble bending them,,I think I may have made mine too long,,they are 2x3's and I dropped the spindle a couple inches too. I used 1/4 wall tubing to extend them.
PostPosted: Fri Nov 20, 2009 3:47 pm
Thanks Marty. I was thinking about doing 1x2's, isn't that what the guys down in kentucky are doing with KP? 1 longer and 2 wider or vice versa? Thank you.
PostPosted: Tue Dec 01, 2009 3:34 am
It's on my "to-do" list for this winter. However it's about third so it might not happen.
Afterburnt made a jig for kp extended arms, I was planing on doing the same for ball joint. I was thinking 1" out and 2" or 3" back.
I'm shure if Afterburnt helps with the design, it will be indestructible.
PostPosted: Tue Dec 01, 2009 2:40 pm
keep in touch with me on this, i would like a set, you guys are only about an hour or so north of me. Brad may be helping me cut my tires, so I'll be up this winter sometime...
PostPosted: Wed Dec 02, 2009 3:10 am
Will Do. I have a good buddy that lives in Green so I am also down there quite a bit.
