PostPosted: Fri Jul 20, 2007 9:46 am
Are these the same?
PostPosted: Fri Jul 20, 2007 11:43 am
[quote='Odyknuck']Are these the same?[/quote]
Both threaded ends should be 11/16"-18.
I hear the newer Ford versions are 3/4"-16.
Tapers are different though.....Ford, I think, is bigger than the IH.
PostPosted: Fri Jul 20, 2007 8:21 pm
International are Bigger, with stock spindles, without the gusseted wrap around you don't want to drill/taper the stock tie rod end hole too much without weakening it too much. Most of the steering racks run International ends on the inside, and the ford on the outer.
PostPosted: Fri Jul 20, 2007 8:40 pm
FWIW the # for the International rod end is ES262R (or L). Took me a while to find it. They fit the rack . I needed rod ends on the outside to fit my bus steering knuckle . I found these on ebay and they fit my bus taper on the outside. Item number: 270021654168. firebug. see yall labor day in Alabama
