It is currently Mon May 04, 2026 4:58 pm
 Post subject: kingpin to balljoint
PostPosted: Sun Oct 11, 2009 10:39 pm
im building a mid 60s vw baja the rear has been converted to irs the frount is kingpin iv heard the you can use balljoint arms in a kingpin beam a little help on this please i know why balljoint its driven on the streets to and its easer to fix on the trailes
 Post subject: Re: kingpin to balljoint
PostPosted: Mon Oct 12, 2009 6:55 am
Can't use ball joint arms in a link pin beam. The lower arm is way too big to fit into the lower tube. The spring profile is different and won't work either.
PostPosted: Tue Oct 13, 2009 12:42 am
Check this out.
http://www.thesamba.com/vw/classifieds/ ... ?id=787535
PostPosted: Tue Oct 13, 2009 12:28 pm
King pin is very easy to fix on the trails, Just keep you an extre link pin, and King pin, and you are good to go. Very easy to change.
