 Post subject: Rear camber angle.
PostPosted: Mon Sep 21, 2009 10:53 pm
I know this has been touched on before. My rear tires lean in at the top a little more than id like and this does not help my cv angle either. It has not given me any problems but i would like to fix it. I have boxed 2+3 arms and they are mounted on correct sides. I have a custom torsion and welded my arm mounts myself. My thinking is they are not exactly where they should be and if they were mounted a little farther forward/higher on torsion housing i would have more positive camber. Am i correct in my thinking or is there something else? I have seen jigs offered to mount them in correct position so if this is what you guys think might be my problem i,m going to buy new mounts and redo them this winter. :?
 Post subject: Re: Rear camber angle.
PostPosted: Tue Sep 22, 2009 10:56 am
swap sides ....add new shock mt on the new side...works every time :wink:
PostPosted: Mon Sep 28, 2009 11:15 pm
Whoa! I swapped sides today. I think i'll just live with what i had. I had just a little neg camber. With them swapped it looks like a swing axle car. Way too much pos camber.
