 Post subject: through rod ?
PostPosted: Sat Sep 19, 2009 3:58 pm
What size allthread do you all use for through rod? I have an idea to use it but I will use the set screw to hold a threaded tube inside the arm ,thus letting the allthread allow the arms to move in suspension and hold the arms to the buggy. input please
 Post subject: Re: through rod ?
PostPosted: Sat Sep 19, 2009 5:47 pm
1 inch.
Or at least that is what they used to ancor the uprights on my building. :lol: Or was you talking about buggys?
PostPosted: Sun Sep 20, 2009 12:03 am
Mine are a piece of 3/4" soild round cut to fit into the main pivots. Then I drilled and tapped 1/2"-13 thread into the ends and put in long set screws bottemed into the end of the thread with locktight. Instead of nuts I used threaded lock collers with brass washers.
PostPosted: Sun Sep 20, 2009 11:16 am
i used half inch threaded rod, on the ends, i used threaded locking shaft collars, and a tefflon washer. and then i had to drill a hole at the end of the rod and put a cotter pin to keep the shaft collar from turning.
dave
PostPosted: Sun Sep 20, 2009 11:59 pm
this what you used?
PostPosted: Mon Sep 21, 2009 12:01 am
or would this be better?
