| front trail arm http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=7425 |
| Author: | mikey w [ Sun Aug 16, 2009 9:06 pm ] |
| Post subject: | front trail arm |
my front tailing has some slack in it. i was was thinking my bearins might be busted but they look fine, looking in the tube. if yall think thats the promblem . how do you replace them? |
| Author: | RaceBugg1098 [ Tue Aug 18, 2009 12:21 pm ] |
| Post subject: | Re: front trail arm |
Its easiest to get the full legnth red bushings. I don't really like 'em, but good luck putting the stock bearings back in a beam thats seen the woods! |
| Author: | hillaholic [ Tue Aug 18, 2009 1:48 pm ] |
My last beam was egged out on the lower tube where the outer bearings go, causing the lower arms to move. |
| Author: | mikey w [ Wed Aug 19, 2009 10:39 am ] |
THANK YOU, so how do i get the bearings out so i can use the polly bushing? |
| Author: | Ringer [ Wed Aug 19, 2009 11:04 am ] |
I used a slide hammer to pull mine out and it worked great. |
| Author: | chris38375 [ Wed Aug 19, 2009 1:16 pm ] |
go from the oppisite end with a piece of small tubing and jus drive them out,i think on my balljoint there is a clip that holds them in |
