| Ball joint spindle stub http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=7412 |
| Author: | hillaholic [ Sat Aug 15, 2009 1:00 am ] |
| Post subject: | Ball joint spindle stub |
I’m wondering if anyone sells just the spindle stub for a ball joint. I found some combo stubs but not sure on the ball joint stub. I don’t want to cut up a good ball joint spindle if I can get the stub cheap. Thanks, Brad |
| Author: | MadMike [ Sat Aug 15, 2009 8:56 am ] |
| Post subject: | Re: Ball joint spindle stub |
I have stock type link pin spindle stubs and I have the big 'combo' spindle stubs as far as I know they don't make a ball joint spindle. You could always make your own ball joint stubs. |
| Author: | aboone993 [ Sat Aug 15, 2009 4:05 pm ] |
Look at Empi part # 16-9914 and see if it can be something you can modify and use . http://www.empius.com/2009_catalog/images/190.jpg |
| Author: | chris38375 [ Sat Aug 15, 2009 10:29 pm ] |
tim at southern buggys ,,15.00 a peice |
| Author: | A. Cole [ Sun Aug 16, 2009 7:46 am ] |
Drews has them $40/pair. |
| Author: | bruce 1 [ Sun Aug 16, 2009 8:54 am ] |
chris38375 wrote: tim at southern buggys ,,15.00 a peice What we use on a K/P. Cut the K/P off use the B/J. Can not beat the price. |
| Author: | hillaholic [ Sun Aug 16, 2009 10:29 pm ] |
thanks guys thats what I need. afterburnt can I use you’re expertise and shop to do my spindle repair? Once I get the new spindle. |
| Author: | afterburnt [ Mon Aug 17, 2009 5:29 pm ] |
ya, your more than welcome, just give me a call, and let me know when you want to come over. I'll pm you my phone number. dave |
| Author: | afterburnt [ Wed Sep 09, 2009 7:34 pm ] |
hey brad, how did that spindle work out? i was kind of curious if you put it on yet, and if that weld got in the way of the seal. dave |
| Author: | hillaholic [ Thu Sep 10, 2009 1:54 pm ] |
The front end is complete. The weld was just touching in one spot so I ground it down a little. I think the upper control arm is still bent because I have major camber that can’t be adjusted. I don’t have time to fix it before this weekend so I am going to run it. Thanks again for the help Dave You going to make it this weekend? I should be there sometime Saturday morning. |
