It is currently Mon May 04, 2026 6:38 pm
 Post subject: Trailer Load Leveler
PostPosted: Mon May 11, 2009 7:07 pm
Putting a new pair of Axles and springs on my lengthened trailer. I have a load leveler for in the middle, but not a 100% on installation. I think I put both shackles to the middle, and no shckle on the center hole of the leveler. Anyone gotta pic so I do this right?
 Post subject: Re: Trailer Load Leveler
PostPosted: Mon May 11, 2009 9:42 pm
Is this what you're talking about?
PostPosted: Mon May 11, 2009 9:54 pm
If it is might want to read up about how they fail with no maintenance.
Axle Equalizer Safety Alert
http://rvtravel.com/blog/rvnow/2007/01/ ... alert.html
PostPosted: Tue May 12, 2009 9:32 am
Yep, thats what I was wanting to see. I have no greese zert tho on mine. And yes I read the report.
PostPosted: Tue May 12, 2009 3:58 pm
Ok so what is the Maintenance with no zert?
PostPosted: Tue May 12, 2009 4:21 pm
According to the Axle Equalizer Safety Alert
grease your leaf spring equalizer assembly every six months.
PostPosted: Tue May 12, 2009 6:43 pm
So just grease the bolt and put it back, ok.
PostPosted: Tue May 12, 2009 9:04 pm
I'm not sure because I never dealt with them but that’s what I get from the article.
PostPosted: Wed May 13, 2009 8:06 am
Its true , they will cause your axles to ride all weird if the bolts arent kept greased up and they get to where they bind up. I went thru three new trailer tires on one side on my enclosed gooseneck before I figured it out :oops: .
PostPosted: Wed May 13, 2009 8:30 am
Hmmmmm, so should I not use it?
PostPosted: Wed May 13, 2009 9:56 pm
I dont think they are any problem as long as you take care of them. I've had no problems with them on my car trailer or camper, the trailer I had a problem with is old and had not been maintained at all.
PostPosted: Wed May 13, 2009 10:08 pm
hey buggy66 any input? he is a rv expert i hear
PostPosted: Wed May 13, 2009 10:22 pm
Well I have them mounted, tacked,welded then removed the axles for painting. Takin a lot of pics of trailer rebuild. Thinkin of posting it just for a practice for my 2 buggy rebuilds.
Jason
