It is currently Tue May 05, 2026 2:31 am
PostPosted: Sun May 03, 2009 11:48 am
Looking for a set BJ raised spindles.PM me if you got a set you want to sale.
PostPosted: Sun May 03, 2009 12:10 pm
southern buggys has jus the spuds,u can make urself,15.00 a peice,
PostPosted: Mon May 04, 2009 11:27 pm
can i see these kits?
PostPosted: Mon May 04, 2009 11:47 pm
Not a kit, just the spuds (the part that sticks out from the spindle, where you put the bearings) so you can weld them to a king pin spindle and run cheaper four lug rotors (like Ghia) but still have k/p front end.
PostPosted: Tue May 05, 2009 10:42 pm
A set on the thesamba for 200 but you need cores
http://www.thesamba.com/vw/classifieds/ ... ?id=747641
PostPosted: Tue May 05, 2009 10:46 pm
damn that high, u can make them for 30 bucks and a little scrap metal,i will sell all u want for 200 dollars,and ive got the spuds in stock,,hahaha
PostPosted: Tue May 05, 2009 10:47 pm
These are combo stubs but just so you know what hes talking about
PostPosted: Tue May 05, 2009 10:54 pm
are them king pin and ball joint??
PostPosted: Tue May 05, 2009 10:55 pm
I didn't say it was a great deal, but if you don’t have the equipment to do it it’s not bad.
They look allot stronger than the ones that originally came on my buggy. My original ones they cut two spindles apart and just used three grade2 bolts to bolt them to the ½” plate. I replaced them with some 5” raised thing spindles that DVS1 had made.
PostPosted: Tue May 05, 2009 11:00 pm
There combo stubs from tweeds $30 each. Larger stubs than balljoint.
http://www.tweedsdesigns.com/img/pages/ ... 0Stub.html
Combo stub made from 4130 chromolly.
Inner bearing 1 ¼”.
Outer Bearing 1”.
Uses stock link pin style aluminum clamp nuts.
Right or left hand tread.
PostPosted: Tue May 05, 2009 11:07 pm
Inner bearing 1 ¼”.
Outer Bearing 1”.
thats cool should be strong,,the ones i bought are jus ball joint spuds,they are still sitting in the shop,i havent done anything with them yet,im gonna raise mine about 2 inches
cron
