stub axle bearings
http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=6168
Author:  joedragracer [ Sat Mar 28, 2009 2:28 pm ]
Post subject:  stub axle bearings
rear bearings are worn out. when i tore down it has the ball type bearing for the inner and outer. i am assuming that this means that it is prior to 1969 setup. question is can i change to the roller style outer bearing and use the same spacers that i already have? is there any reason why i should or should not change to the newer outer bearing?
Author:  chris38375 [ Sat Mar 28, 2009 2:41 pm ]
Post subject:  Re: stub axle bearings
if it had ball type bearings in the inner and outer,its wrong,if i can remeber right,ball bearing goes inner and roller goes outer,i may be backwards,auto zone has them and can tell you
Author:  joedragracer [ Sat Mar 28, 2009 2:45 pm ]
ok, but when i looked it up it on cb performances web site it shows only one part # for the pre 69 t1? it listed an inner and outer for the 69 and later. thanks, jd
Author:  chris38375 [ Sat Mar 28, 2009 2:48 pm ]
swingeaxle or irs???
Author:  joedragracer [ Sat Mar 28, 2009 2:51 pm ]
sorry, irs
Author:  chris38375 [ Sat Mar 28, 2009 2:59 pm ]
all the ones ive ever messed with is 2 different bearings,,timken bearing inner part number is ;;206WB;; outer is MA1206EF
Author:  joedragracer [ Sat Mar 28, 2009 3:04 pm ]
thanks
Author:  ky-bc [ Tue Mar 31, 2009 9:01 am ]
SKF part #'s
6206 C3 for the ball brg.
NU 206 ECP/C3 for the roller brg.
DICHTOMATIC TCM 43 X 62 X 10 SC (replaces 16939) for the seals.
Author:  turboblue [ Tue Mar 31, 2009 10:36 am ]
VW part numbers:
113 501 283 is inner and a ball bearing.
113 501 277 is outer and a roller bearing.
113 501 315 is the seal number.
Two required per side.
Author:  jesse [ Fri Apr 03, 2009 2:57 am ]
i just did mine tonight the ball one is inner
