It is currently Tue May 05, 2026 2:49 am
PostPosted: Fri Mar 06, 2009 10:41 pm
After removing the axle shafts from the buggy a month or so ago, I now find out that I should have labeled them Left and Right. Is there a way to figure out which is which? Also, how would I tell them apart from stock ones? The CV's are Lobros.
Thanks
PostPosted: Fri Mar 06, 2009 11:33 pm
I know if they are aftermarket they should have a L (left) and R (right). I'm not sure on stock ones.
PostPosted: Sat Mar 07, 2009 4:27 am
there is also a left and right on your torsion bars. i know a guy that couldn't get his suspension to stay up for more than 1 ride and it was because he had his bars in backwards, hell I didn't even know there was a L and R on them until pipedope mentioned it to me at the coldspot, now my suspension should stay where its at, i mean the guy i knows haha.
and i believe there is no left and right on stock axles because there is no torsional effect with stock axles so it doesn't matter which side you put em on.
"Lets go get stupid"
PostPosted: Sat Mar 07, 2009 8:22 am
there are no marks on stock axles. Axles are less likley to break if you keep the stress in the same direction. I've aalways known this and never seem to mark my axles, luckily I have never broke an axle, Knock on wood!
PostPosted: Sat Mar 07, 2009 11:39 am
Ok, thanks. I dont know if they are stock or aftermarket axles. But the cv's being Lobros are aftermarket, correct? And if they are, then i am hoping there is a L and an R on the axles. I did notice there are some markings on the end of one of the shafts I looked at, but I didnt pay any attention to what they were. Will be looking shortly. Have to pickup some marine grease for the CVs.
PostPosted: Sat Mar 07, 2009 8:37 pm
would that be L for drivers side
Tony
Tony
PostPosted: Sat Mar 07, 2009 10:32 pm
Lobros are stock but they are better than most aftermarket cv's. If you clock them, race prep them and don’t go above the max angle they can handle, they will last a long time.
Tony
Yes, anytime they say left or right it is as you sit in the car.
PostPosted: Sat Mar 07, 2009 11:23 pm
I have heard that Caterpillar Desert Gold grease is very good for CV's.
PostPosted: Sun Mar 08, 2009 2:22 am
I wish I would have known about the cat grease. My daughter's boyfriend just left Cat in Peoria, IL. Oh well.
Update on the axle shafts: No L or R on either end. So I am guessing they are stock.
Repacking the CV's is a tedious process. Any way to make it easier/better?
I remember reading somewhere that prior to re-installing the CV's, the pocket of the tranny output shaft andn the pocket of the stub shaft get filled with new grease. Is this the way to go?
Thanks for all the help.
PostPosted: Sun Mar 08, 2009 2:35 am
On stock axles the splines are about an inch and a half long with a shoulder, and the aftermarket splines are more like 2 1/2 inches with no shoulder,,,the cv will actually slide out into the middlw of the shaft. As far as grease,,,I don't think you can get too much grease . Hint,,,use latex or simular gloves :wink: Also for best travel,,,read on "clocking " in Outfront motorsports
http://www.outfrontmotorsports.com/cv_assembly.htm
