| axle length http://woodsbuggy.com/phpBB3/viewtopic.php?f=4&t=5856 |
| Author: | J.DiNapoli [ Fri Feb 20, 2009 11:45 pm ] |
| Post subject: | axle length |
What axles do I need to bus to bus w/ stock trailing arms. I know i need Thing stubs. Ive tried sway-away 15 5/8 w/ long splines going bus to car but axles were to short, no free play between cvs. I currently use bus inner cv w/ stock car axles no clip and car outer cvs w/ clip. I was sideways on a hill, and somehow axle pulled from bus cv.I was going to have bus cv cage bored out enough to fit clip in like Kyle posted last year. Any suggestion? |
| Author: | Kyle [ Sat Feb 21, 2009 10:23 am ] |
| Post subject: | Re: axle length |
bus to bus with stock arms you really need to do what was in the picture. i never broke a single joint that way. just take the centers to a local machine shop for 20.00 they can lathe them out real quick and you will be set. just whatever you do make sure you have 1/4 play in the axles with them flat. you can get other porsche axles and stuff i believe but just cutting those down is so much cheaper and simple |
| Author: | harleyhunter05 [ Sun Feb 22, 2009 12:27 am ] |
i run porsche 924 axles -- bus to bus. I think thing axles are the same length -- wait for a second opinion on that to be sure |
| Author: | bradley59dzl [ Sun Feb 22, 2009 11:47 am ] |
J.DiNapoli wrote: What axles do I need to bus to bus w/ stock trailing arms. I know i need Thing stubs. Ive tried sway-away 15 5/8 w/ long splines going bus to car but axles were to short, no free play between cvs. I currently use bus inner cv w/ stock car axles no clip and car outer cvs w/ clip. I was sideways on a hill, and somehow axle pulled from bus cv.I was going to have bus cv cage bored out enough to fit clip in like Kyle posted last year. Any suggestion? yea i have porsche axles w/o cv's , and stubs for $125.00 and that would solve it |
