It is currently Mon May 04, 2026 6:38 pm
 Post subject: pipedopes bump stops
PostPosted: Wed Feb 04, 2009 11:47 pm
Pipedope I am looking for ideas for front bump stops. I will have tubing on the outside supports of my beam. After looking at several pictures I found yours. It looks like you have a tube coming off the beam with flat stock welded around your arm. If I am seeing it correct it will act as a compression and extension bump stop. Is it just metal to metal or do you have urethane snubbers in there. Has it held up? Do you like it? Would you do it again? Do you have any better pictures to share of the bumpstops.
Thanks, Brad
 Post subject: Re: pipedopes bump stops
PostPosted: Thu Feb 05, 2009 11:29 am
I will let him know that you are asking for him to help you out on this modification, he has been out of power for quite some time now and still don't know if it came back on yet......I will give him a call and let him know what's going on here and if you would like to I can give him your number and he can call you.
