It is currently Mon May 04, 2026 12:16 am
 Post subject: Rear Trailing Arms
PostPosted: Fri May 25, 2007 10:24 pm
Has anyone done anything with parallel swing trailing arms?
What I mean is the inboard and outboard pivots are parallel to the centerline of the rear torsion housing. This would keep the tires flat to the ground through out it's travel.
I'm going to be building a set of 3X5 arms and wondered if a parallel set up has any advantages or disavantages. Any thoughts or suggestions?
PostPosted: Sun May 27, 2007 10:28 am
Looks like I jinxed myself big time. During my ride at Wellsville with DVS1, PlumberBill and Odyknuck on Saterday I managed to tear off my passenger side trailing arm. Pictures to follow from PlumberBill which should be interesting. Now I need a new set of arms. I guess I'll be known as Tripod or something for a while. BIG thanx to all for getting it out of the woods and loading it back onto the trailer. It won't be forgotten.
PostPosted: Mon May 28, 2007 6:53 pm
had a good time with odyknuck, madmike and hawiian dave, just wish we could of rode longer we were just getting warmed up. pics were taken with a cell phone, not the best but you get the idea.
- Sigmund Freud
- Antonio Meloni
PostPosted: Mon May 28, 2007 9:05 pm
Hill Climber
I have never seen that damage before. You must have hit HARD.
I'm not sure about the idea of keeping the wheel flat throughout it's arch. The axle may bind up in the center of your wheel travel. To do what you are thinking I would think you would need an axle could slide in and out.
I may be wrong.
PostPosted: Tue May 29, 2007 3:51 am
Wow what brand are those arms Mike? Are they the china knock offs oops no pun intended
PostPosted: Tue May 29, 2007 8:59 am
china knock offs :lol:
- Sigmund Freud
- Antonio Meloni
 Post subject: Three legged dog
PostPosted: Tue May 29, 2007 10:47 am
Ya know Mike the pic of you being towed would have been better if your tounge was hanging out. Then the Three leeged dog name would fit perfectly. It was great to meet you and Dave. Hope to get to ride with you guys again soon. Dave get to work on that Buggy.
PostPosted: Tue May 29, 2007 9:25 pm
I think I hit a tree when we were taking that back trail up to The Forbidden Zone, where PlumberBill got stuck. I think that's where things got started and it wasen't long from there till it unhinged. No they are not Chinise crap, they came from a design I got from another web site whos name I won't mention. What failed was the 1/8" plate on the outside of the arm by the bearing housing, it just tore the bearing house right through. The welds were all intact with big chunks hanging off. The replacement arms, 2 X 5 with all 930 parts, they are already started and I don't think I'll break these. :roll:
PostPosted: Wed May 30, 2007 9:21 am
mike, i wonder if that stump where i got stuck had anything to do with starting the problem. it was really hard to tell cause you came up that hill like a pinball..........................you gonna be ready this weekend :?: :mrgreen:
- Sigmund Freud
- Antonio Meloni
PostPosted: Wed May 30, 2007 7:59 pm
That could be the one. It is a tight trail and that's what it felt like.
Not this weekend, maybe next, waiting for parts.
 Post subject: TREE BREAKS
PostPosted: Sun Jun 03, 2007 11:12 pm
Dam,I hate when that happens.Been thier done that,got broke parts to prove it.Sorry to hear, but I know you will build it better than before.
PostPosted: Mon Jun 04, 2007 9:38 pm
Yes I did exceed the design limitations on that one, live and learn. Hell all I'm doing is relocating the weak spot, stronger arms, 930 CV's and axles. What gives next, stub axles, inner pivots your guess is as good as mine. It's safe to say it won't be trailing arms again.
PostPosted: Mon Jun 11, 2007 2:16 pm
Dang, you guys run some BIG tires.
Imagewww.F-O-A.com
PostPosted: Mon Jun 11, 2007 4:47 pm
Its all about traction and/or ground clearence!
PostPosted: Mon Jun 11, 2007 9:26 pm
[quote='Motochris']Dang, you guys run some BIG tires.[/quote]
31 X 15.50 X 15 on 14" wide beadlocks. It does get the job done.
PostPosted: Tue Jun 12, 2007 12:07 pm
mike, how the new arms comming along
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Jun 12, 2007 9:14 pm
[quote='plumberbill']mike, how the new arms comming along[/quote]
Moving right along, was trying for this weekend but there was a hold up on my axles so looks like it's going to be the weekend of the 23ed.
PostPosted: Tue Jun 12, 2007 9:17 pm
[quote='Chaindrive Rail']No, 18 X 44's with 180 steel studs gets it done. :twisted:
Curt[/quote]
Ya, your right Curt, maybe someday.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
